Engineers, Anyone Know Any? Prefer Melbourne
hey thanks man!
hrmm thats gay, i read it all and it says it only lasts 30days, i though it was somthing you can carry around as proof your car is all legal. My car is already registerd with the rb25det so no dramas, but you know, the police :P
Being registered with an rb25det does not mean it is legal. :unsure:
But i didn't know about the 30 day thinggy.  There must be something that is permanent.
well yeh, other wise i couldnt register the car, its cause its a smaller capacity i got away with it.
ive been pulled over, no dramas, i have all necersary upgrades, so i mayaswell get somthing on paper to shut up the picky cops
what that means is for example....i put a rotary in say a nissan micra i got 30 days to get to vic roads to get it registered or let them view the vehicle to change there database..
but they wouldnt register it with out the proper upgrades
The rules were changed when the VASS scheme was introduced 5 years or so back, basically to bring engineers certificates into line with RWC practices (ie expires after defined period if not presented to VicRoads). The certificate is 'permanent' once accepted by VicRoads and goes into their records, the owner also gets a copy (or should) from the engineer. That is: original to VicRoads and car owner also gets a copy.
Al is right, it's not legal. Doesn't matter that it has smaller capacity - quite apart from the fact that the power output is more than 10% over the standard engine's output, the Rb25DET wasn't offered as an option for the R31. You need an engineers certificate - if nothing else your insurance is invalid.
mate all i can say is what ever you do even if u live next door to this bloke dont even bother going to him. Guys to f*@#en strict.
PAul bottemly and hes in heidelberg
A really good engineer ive found to be is Archie Robertson hes in bayswater
Spot on. If you get pulled over they will ask for engineers etc and if you cant produce them you'll get a fine and i'd say have your registration cancelled. IF you've done things like upgrade brake system etc then you wont have a problem getting an engineers cert. What was said about the 30 days was also spot on. You have to produce it to vic roads for it to be vaild, after that laminate it and store it in a safe place.
Archie is alright but he picks on so much little shit, like the rear numberplate. The distance was spot on perfect and met vic roads regulations, But i still had to shave off 1mm either side of the plate so that there was a small gap between the plate and the reverse lights. I asked him what that was about considering cars off the showroom floor have those number plate plastic surround things and all he said was vic roads told him to make me do it. Too much little shit.
Is this for an engineers cert. If so you'll have to get in contact with Vic roads and get a list of engineers off them. Sanjay or something like that out of warntirna south is pritty good.
He is forgetful, and changes his mind every time he looks at your car. He's also in Glen Waverley, and will come to you. I don't have his details though.
Will charge $500 for an engineers cert. Inc. chassis and structural inspection. And braking distance and fade test.
Went thru this process when I had my R32 RB25DET
just to clear up some misconceptions, doesnt matter engine capacity, R32s even came out with Rb25DE and they said I still need a engineers.
Engineers can be real picky if they want to be as well with certain things.
Cops dont care if ur cars registered with it or not, you get the wrong copper and he knows its a conversion, thats it, I was a bit unlucky because the RB25 didnt look outta place in a R32, but in a R31 it certainly does.
I dont really see the huge point in getting it engineered anyway, theres still EPAs and defects to worry about, thats why I sold the car. As someone mentioned, for insurance purposes as well, it can be a problem.(even if you have 3rd party).
Some people choose to take the risk and run without changing anything, you most probably would get away, but theres always that chance.
but still, it being engineered dose help!
    • Convert to dual filament bulb   FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed.
    • If the RB20 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
