Engineers, Anyone Know Any? Prefer Melbourne
He is forgetful, and changes his mind every time he looks at your car. He's also in Glen Waverley, and will come to you. I don't have his details though.
Will charge $500 for an engineers cert. Inc. chassis and structural inspection. And braking distance and fade test.
this sounds like the man i need to see :blink: , anyone know how i can track him down?
Im not reall %100 sure about everything..
But when i do go get a engineers certificate, it will state that my car is legal with the neccersary mods, would i need to go back to vicroads with this? or just keep a copy in my glove box? with epa, ive fitted everything like the charcole canister/airbox/cat.
But other than that, it been engineerd can save me alota of hassels right? and if he says no he will tell me what i need to get done?
thanks guys
Nate
Being registered with an rb25det does not mean it is legal. :)
But i didn't know about the 30 day thinggy.  There must be something that is permanent.
what that means is for example....i put a rotary in say a nissan micra i got 30 days to get to vic roads to get it registered or let them view the vehicle to change there database..
thanks guys
Nate
:blink:
thanks guys
Nate
dude,
i have a friend who is a qualified mechanical (automotive) engineer that can help you out.
he is really good and only wants to do the job one way, and that's the right way.
his name is Paul Bottomley and he is part owner of APS( Automotive Performance Solutions) over in Heidelberg, give him a call on 9455 3222.
let him know that u know myself (goran - rs500), and he should help you out.
cheers.
, i though it was somthing you can carry around as proof your car is all legal. My car is already registerd with the rb25det so no dramas, but you know, the police :P
If the car is already registered with an RB25, then thats all you need to worry about.
but still, it being engineered dose help!
No it does not help one iota.
so i mayaswell get somthing on paper to shut up the picky cops
You cant get it engineered with a PowerFC
You cant get it engineered with a boost controller.
You cant get it engineered with a I/C and a pod etc etc etc
If thats what you think an engineer is going to approve... then your mistaken...
You would also need an emissions test if thats what you wanna do... and that isnt cheap.
End of the day, if its registered with an RB25, then the police cant do anything relating to that if the motor is in standard spec.
What exactly do you need an engineers to "stop" the police picking?
hrmm many things in this thread conflict, but i trust your word ash!
When i got pulled over he only picked on the pod and didnt say a thing about the cooler, he assumed i had the rb30e and turbo'd it. Epa sent me a letter, but just said to fix it, i didnt have to go there phewf
If its rego'd with the RB25 and you got an EPA
just rock-up to the EPA and they will go through the checks for the RB25 :D
The EPA dont give a rats a$$ what motor is in the car, only that it has the pollution gear associated with the motor that is in there when you go for the test etc etc
I'm not surprised the OP is confused after this sort of statement, particularly when I thought we'd already sorted this. Anyway, it's very simple:
The OP has an Oz spec R31 now fitted with an RB25DET. The fact that engine was not offered by Nissan as an option for that model means that, by law, he requires an engineers certificate (ie VASS) to show that the conversion meets VicRoads engineering requirements, plus Vicroads might also want to inspect the car. Also:
- the fact that he was able to change the engine number just means that the drone at Vicroads simply didn't know what he/she was looking at;
- ditto for any cop that doesn't pick it up - which is probably just dumb luck.
- ditto for a RWC inspection.
All the requirements are shown on the Vicroads website. Without the engineers certificate the car is illegal and all his insurance is invalid.
He said it was registered with an RB25
That means
1) It says RB25DET on the rego sticker
2) It has RB25DET on the VicRoads records.
If its got to that point, it doesnt matter what did/did not happen in the past at the time of motor alteration.
When you go in to change that the VicRoads officer shouldnt let it pass without the correct documentation.
If VicRoads due to thier own poor ability to monitor staff have changed the record, then you've had a win.
Same for canaries that just "disappear" off the system sometimes :D
That means
Same for canaries that just "disappear" off the system sometimes :(
that reminds me, i need a new sticker, and yes the car is registerd with the rb25det..
AFAIK i didnt no much back then, so got a rwc with the car ect... and went to vicroads like you normaly would, and that was it :mellow:
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
