today my car was getting tunned and everything was running sweet then the AFM started giving out different reading..
no im no expert so im trying to repeat what i have been told.
A faulty AFM i have been told will give a very high or low reading, well mine was going up then down then centre...?
the tunner has never seen it before in all his time remapping ECU's (which he was doing with mine)
so basically he said even a 0.1 volt can make a massive difference in the high end voltage.
anyone had this happen before, or any tips?
(we are going to try a different z32 tomorrow)
disclaimer: if i sound like i dont know what im talking about its because i dont, just relaying info.
thanks
https://www.sau.com.au/forums/topic/101253-afm-giving-different-voltages/
stock ecu has no concept of how much boost you are running.
does the afm voltage vary much at idle? if its hunting around then the afm will vary a little as it will suck in a bit more air when it tries to stall recover. is it a new z32 or 2nd hand ? do u know when it last worked ok?
it was 2nd hand, i was told the voltage varies constantly, then later in the day was sitting in centre..
i was also told that when a particular sensor was turned off via ECU tunning there was no detonation
by moving the wires about do any of the voltage readings change??
hows the car coming along??
ill have a play around with the wires tonight, cars fine apart from this..
a touch laggy
if it doesnt get fixed after trying a new AFM i quite the whole remap ECU route
nothing wrong with a remapped ECU mate, you just need the sensors to tell it the right things....but I'm not 100% sure from how you described it.
Do you have a consult cable? datascan and similar show great data on the health of all the sensors to help you track down problems.
im not sure either...
i dont have a consult cable.
last night we tested 4 z32 AFM's on a 180sx
mine and another were giving out different readings, the other 2 were practically the same.
mine was running the 180 rich
I would be checking that the AFM is getting a nice constant supply voltage.
I would check that with the airflow meter disconnected that it reads low volts <1V and sits constant until i blew through it to jump it to >2V. (Need bench power supply connected of course)
I would disconnect the harness and measure resistance/check continuity through the signal wires to the AFM. (make sure there is not bad connections or piggyback devices hidden in the system)
I would do the wiggle test over all connections.
I would subtitute a 0-5V supply through the signal wire and check with a suitable consult/scan tool, that the reading did not fluctuate on the scantool hooked to the ECU itself.
All whilst measuring the actual voltages at the ecu end with a multimeter to see what was actually going on.
Well thats what i would do, coming from an auto elec.
Sorry if none of it makes sense, but if your tuner does not do the above, he will never know or rule shit out.
Shouldn't be to hard to sus it out, if he cant take it to someone else.
will pass on the info!
thanks!
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
