  • Replies 56
but he used a Gates timing belt and no note of replacing the idler bolt!!!
And?
The idler bolt isn't a torque to yield bolt, why would it need to be replaced unless there was something wrong with it? I've done 30 or more RB's and never replaced one?
What is the problem with a gates belt? Is it that it's not called a "High Tuned Hyper Super Ultra belt for timing situations" and costs $350 more? They are stronger than a standard Nissan belt and they are also a pretty blue colour so they look fully sick with your anodised cam gears when you leave the cover off.
ok one quick question.. n1 water pump flows more or less than standard?
N1 has less vanes than a standard water pump, plus has an anti-cavitation plate. It's designed for an engine that spends most of it's time at high rpm....ie a race engine.
The standard pump will flow more at any given rpm, which is why it is best used on the vast majority of street driven cars.
  • 1 year later...
I dont see how you guys are factoring 1000-1500 for pulling out the engine. Its simply rediculous.
The last one i did in a garage (no hoist) and a shitty hire crane we had the engine ready to be removed in under an hour. It took another 15 mins to get the thing out as it was a little bit of a mission angle wise.
Im getting my block and head rebuilt next week so will be able to add in some other prices but i think some of the comments here are pretty rediculous. Just because its an expensive job doesnt mean its any good.
Parts so far anyway (most were on a discount admittedly)
Bearings (acl race) + head rebuild kit incl tensioners 627.00
Cambelt 50.00
Crank collar 120.00
Water pump (rb30) 27.00
Restrictor 15.00
Bearings (pistons are near new) 247.00
I cant see how even if i get forged pistons & rods (2500 ono) and a Jun pump (600) its going to cost another 7k to rebuild the engine?
Edited by SirRacer
Sorry mate, was doing a search on some information i was after and didnt realise how old it was.
The engine is in a cefiro so there is a little bit more room, but yeah it was relatively easy. The hardest part was getting some of the loom clips unattached. We have done quite a number now so they are getting easy.
Say a shop is charging 95 per hour, its effectively taking 10 hours to remove the thing when someone whos very average with a spanner set (i work in a bank) is doing it in way less.
i agree with duncan. i except i will pay you two hours labour just to do it.
i am looking to have my motor pulled out now to sort the oil control issue out. just slowly putting money aside as i want to do it all at once and a set off cam's with a mild port and polish while the heads off.
not gonna be cheap.
I'm getting my R32 GTR engine rebuilt atm in it has cost more than I sold my other R32 GTR for - and that was a good car in good nick that I got a fair price for. And the car still isn't ready!!!!
People commenting in this thread for a rebuild for less than $10k. I wish.
perfecting timing of this thread making a return, as i beleive ill be needing a rebuild.
engine is on its way out (hopfully tonight) so i can bust it open and see what the knocking noise is.........
worse case would be a full rebuild, which i plan on doing using all stock parts (or after market if prices are close) not looking at making huge power, i just want an engine that will last daily driving.
steve
10k is not too bad...! Thats if its done properly,machined to good tolerances etc.Many builders take many shortcuts.I would go the external oil pump even over the N1. Yes N1 is a better design but it still isnt flawless. If ya think 10 k is pricey..jump on to Tomei's webpage and see how much they sell crate motors for...Ridiculous...you can buy a neat GTR for the same money
I think someone has to define: Rebuild.. Many of the rb26 parts won't need replacing if you only wana run a few hundred kw's and if you just want it rebuilt so you can drive it same story... but a rebuild for 10k i'd be expecting to see performance improvements over stock and a 15k one i'd want to see 500kw reliably :P:D
My first gtr had the engine built, drive in drive out $9000
CP forged pistons/rings
Eagle H-beam rods
ARP rod bolts
Tomei sump baffles
Tomei metal head gasket
Reco stock head
acl race series bearings
N1 oil pump
Gates Racing tming belt
Extreme clutch
machining, paint, reassemble and install
This was by Boostworx in SA.
Edited by fieds83
What was the rate for labour and did you supply the parts or did Boostworx supply them for you?
Edited by benm
That was drive in drive out, they sourced the kit from Hi Octane Racing. Boostworx are very well organised, efficient and easy to deal with.
Sorry i passed the recipts on to the new owner so i am unsure of exact amount for labour.
Give Shaun a call he will be able to give a reasonably accurate estimate. There were no nasty surprises in regards to price.
Edited by fieds83
That's fair enough, what I was getting at is many people do a "drive in drive out" and get the mechanic to organise the parts. You only have to look at difference in parts pricing between your local supplier and that of say Nengun and you could save anything up to 50% just in parts alone.
Then you have labour charges, take your car to an import mechanic that eats and breathes skylines or take it to your local mechanic that you have known and trusted for 10yrs that also knows your engine and you could save another 50% just in labour charges. A good example of this is tuning costs around Sydney between the internationally recognised tuners vs the small time mechanic tuners.
Totally agree that experience is the key, the only drama with Nengun and the like is the timeframe. Hi Octane had the kit ready to go and i did not have to worry about getting slugged unexpected import duties etc
I am sure it probably could have been done cheaper in regards to parts though i bought it like this and its not necessarily the approach i would have taken. Personally, not being in a hurry i would have shopped around for the best prices though most shops go with what they have direct access to.
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
