My cousin has asked me to find him price to buy 6 inch lift kit for his new ford F350 its crazy its like 6 meters long and he got the muffler guys to put 2 holes in the tray and put pipes like the trucks have sticking straight up into the air on either corner. its makes some crazy sounds.
not sure if this is legal l but it cost him heaps and also had custom extractors made at the same time . he says it legal cause its like a truck or is one cause of the size of truck but i am not convinced by this...his a nut. anyays he asked me to find him 6 inch lift kit plus also. 8 stud 22 inch rims plus tyres...which are to be chunky...he was told that you cant get 8 stud wheels here for that car here so they have to order thme especially for this car from overseas......any places to find this stuff in oz or overseas would be great.
regards brian
http://www.oppositelock.com.au
Try ringing an opposite lock store and see if they can order some in. Or email them. Now get the F Series shite off this forum!
Nah bugger that. I want pics
Here are some pics of what I am imagining it would look like. My guess is that the first one (minus the lambo doors) would be the closest to reality. But here they are:
24 inch lift kit :lol:
Hmmm... I serviced my car the other day, and getting underneath it is always annoying. Maybe I should go the 24 inch lift kit on my GTS-T. My Nismo adjustable coil over suspension just doesn't compare!
Edited by Big Rizza
Geez you guys are nasty....My car is a R33 Nissan Skyline and this is
the only car forum i use so i thought i could get some help from you guys. or set me in teh right direction...since you are smart......lol and i have had problems looking through and sifting through all the crap on the net. i thought maybe some of you guys would know or be able to set me on the right direction and i thought it would be ok to post here as this is the general automotive discussion section...For disussion relating to all other cars, bikes and other powered vehicles.. Im located in Melbourne Victoria
, the rims on that last one would be what he is looking for i guess.
yeah that red one with the exhasut coming up is sort of like his but his pipes are bigger. he wnats 22' inch rims but im guessing you dont put fat tyres on those....well any help would be apreciated
these are some of the F750 i think not the F350
Edited by el_bichito
Hey,
You'll get better answer at a forum that specialise in offroading than here as the car in question is a Ford F350.
Google for some F series based forum as you will get better answer, advice and knowledge from the owners mouth.
Might worth asking the guys at www.outerlimits4x4.com about these or other offroad based forums.
Cheers
Grant
A 6 inch lift would make it look like this
Which is just stupid.
A 4 inch suspension lift is usually called a 'superlift' as you need to change alot of other parts in the car to accomodate for the extra height on the chassis.
To go higher you will need a body lift.
1 of our work sites south of Cairns has 6 of these new F350's as company cars.
I have driven 1 once, and they wont go much more than 130 km/h. With a suspension lift and 22's it would be a pig to drive
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
