Finally got around to having a look at my RB26 head last night and found more wear than I'd run it with in some exhaust guides . SK once said that this is not uncommon for these heads due to the Japanese refusing to change their oil . By the nature of these cars you'd have to say that most of them have had a hard life in the old country as well .
I'm curious as to why a cam lobe over bucket valve train would allow enough side load to wear the guide (or valve stem) - are the std exhaust guides a little on the soft side ie some sort of exotic Hidural Bronze or some such for better heat conduction ?
Can I take it as granted that K Lines are not an acceptable fix .
The burning question is do these heads eat valve guides over time even with good maint/oil/bit of mechanical sympathy ?
My previous experience of this kind of valve train ie FJ20/4AGE/7MGE is that the guides seem to live forever so this is new to me - though was told to expect it .
I guess this leads into what makes these valve trains reliable long term . A good friend of mine (SC) who's been on the tools for ~ 30 yrs said that while hollow sodium cooled valves are good , if they hit anything they tend to break rather than bend . He was recently given two transverse 4AGE's , one of which had dropped a valve or seat and destroyed the chamber and daylighted the piston .
Obviously no one intends for this to happen but I prefer bent valves to destroyed engine .
Also while I'm here , some in the aftermarket are offering different buckets to go with reduced base circle cams for more lift and alternate material guides . Is this the way to go - dread to think of the cost ? Wish list includes highest lift ~ 260 cams but at what cost .....
Sorry so long but need all the facts , don't want to do it twice .
Cheers A .
https://www.sau.com.au/forums/topic/101317-rb26-valve-guide-wear/
Cheers  A .
i'm sorry if you already knew this but you are awhere that the rb26 exhaust valves run very large clearances i believe because of the sodium find valves that exspand conciderable when they heat up. I found this out rebuilding the last two rb26 (R34,R33) the head shop thought the exhaust guides were gone but once we checked to factory tolerences we found that was how they were surpose to be setup quiet loose.
pete :O
Have you measured your guide clearence?
RB26 max EX guide clearence is something like .004"
(will feel quite loose with valve in guide)
Factory guides are cast iron and prone to cracking,
I change guides in brand new heads for bronze guides in BIG HP GTRs.
Klines are definately not an option.
I have seen a few bent sodium filled valves (RB26 and others) none actually broken.... yet.
You'll find if you check the exhaust guides with a 7mm valve seat cutting pilot they will more than likely be ok. They do feel like they are pretty rooted (technical term) if you check them with the valve.
Edited by proengines
  • 5 years later...
I'm sorry for reviving an old topic, but I've got something to ask.
So there is ABSOLUTELY no need to use sodium-filled exhaust valves if an engine doesn't feature forced induction and I want it to be pretty durable, right?
I'm building a russian engine in 4AGE style, changing all the valves to light 6 mm stem ones. I've got a set of Subaru WRX STi sodium filled exhaust valves, but they would require larger clearences than solid ones, would they? So if I'm likely to build the engine in Toyota durability style, I'm better to switch to solid valves and tighter clearences.
The engine is quite known for burning exhaust valves, that's why I've chosen the WRX STi sodium-filled exhaust valves. (They are almost completely identical, only +0.5 mm in height)
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
