Hello peoples of the QLD region... Incase you dont know.. I'm Biki ala BikiR0M...
Moved here only last week, now i'm here to live.. AH! no more WA... not to worry.. it was cold over there.. didn't even get a 30degree summer day.. Here is the win...
Anyhow, i'll be coming to this thursday's meet carwhoring with someone as my car... ala bunky wont be here until next week when TnT decide to be nice and deliver it to me.. bastards..
so.. HI!
ps... damn there are alot of nissan's over here...
https://www.sau.com.au/forums/topic/101320-hello-qld/
so.. HI!
Welcome mate you should enjoy your time over here and I dare say you'll have you hands full of ROM orders aswell...
https://www.sau.com.au/forums/topic/101320-hello-qld/#findComment-1851123
so.. HI!
Welcome :rofl: Ahhh another wa'er sees the light!!
Might have to get myself to this thursdays meet...
https://www.sau.com.au/forums/topic/101320-hello-qld/#findComment-1851184
correct... i would be one of them... but already booked in with spry :rofl:
https://www.sau.com.au/forums/topic/101320-hello-qld/#findComment-1851209
30 degrees, where did you live - the deep south?
Last time I was there, there were several days over 30. Also the lack of humidity means flys were everywhere, I even had to get one extracted from my eye.
Anyway enough babbling. Are you doing similar business here?
https://www.sau.com.au/forums/topic/101320-hello-qld/#findComment-1858102
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
    • Running rich in conditions where it shouldn't probably won't do great things for catalytic converter lifespan. I would fix that sooner than later.
    • Yes, important point. Watch the Motive videos with Herman thickness testing the bores and deck. You do not want to push the unlucky (thin) block as hard as you can push the average block.
    • Make sure to have the block checked for cracking etc before doing anything.
