if you are using the 400wrms item look at a VPA11500.thats a 1500w monoblock.
also the 80% off retail. I think not.
Gee umm.... My apoligies about the price. And yes, I will be going for that amp, just been added to my contract :(
what would you like to know about the brand.( I sell the complete line.) also did you chat with the dealer or the manufacturer?
the screen you mention hasn't been released yet. I'm waiting on one currently.
I'm going through the manufacturer in America. They offered the screen to me... So maybe its been released in the US?
All I wanted to know is if the gear I have mentioned (with the edition of the new amps) would be enough to crack late 140db's? (with proper sound deadening as well)
Monoblock amplifier with 3000 Watts max power and 1500 Watt RMS
Max. Power@4 ohms 1x3000 watts
Max. Power@2 ohms 1x 4500 watts
RMS Power@4 ohms 1x 1500 watts
RMS Power@2 ohms 1x 2200 watts
VPA 11500 great amp hasn't let me down.....
With the gear you have you should have no problem cracking 140db's
Once you've tried the head deck especially if it is there new dvd navigation head deck can you get back to me on performance only thing that really worries me is the 50Wx4 power of the unit there is alot of higher powered head decks out there.
AMS,
could you fire me a PM with whom you are dealing with. there's a blau dealer in tamworth currently so why bypass them.
after talking to the regional manager of SE aisa in melbourne(who had a chat to the US manager) he says that there is not currently a sponsorship program going nor vehicles being sponsored.
NEO,
the screen/DVD he's mentioned isnt the aspen ( the only ones available are prototypes and these are still in testing.). could be a chicago. to answer your question on power - the chicago does 26wrms /ch and hammers . still better to use an amplifier on them.
VPA 11500 is great isn't it! used one on a set of VPW300s on a slightly tuned box in a hatch and broke 152.
so 140 on the proposed setup is definitley doable.
    • I’m hosting a bunch of execs in the McLaren box on Saturday. If you’re around I’ll come say hi, and see if I can sneak out some freebies.
    • Yes. All of this. But even when you get the NOx as low as you can go on an RB, it will no doubt still be way too high. Same with CO and HCs. The tech and the tuning time just isn't there.
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
