hi guys,
this thread is targeted at people that own/have experience with power fc's...
i have a PFC Pro installed on my s13 running RB25DET... now i am sure that all PFC "PRO" models have L/C ... this should be found by selecting "REV LIMIT" and then hitting the "NEXT" button...
but when i try to get to it, it simply doesnt work... i press "NEXT" , arrow right and all possible keys (that i know of ) and nothing happens...
What am I doing wrong now??
here is a pict taken of my installed and running PFC...
thanks in advance
https://www.sau.com.au/forums/topic/101353-power-fc-pro/
did that paul... it just didnt work... i have read in a few forums that this is the way to do it... but the solution is/was so simply that it hurts my brain :P
it's the one below engine REV -the one set to 4000- :) - silly huh?
i have no idea whether this is normal for the PFC to have it displayed there, but this is where its on mine... i changed it down to 2000 rpm just to be on the safe side, and it kept the revs on 2000 ... no clue WTF those silly japanese call it A/C ?? ;)
anyway, thats the solution and it sounds ILL !!! :)
https://www.sau.com.au/forums/topic/101353-power-fc-pro/#findComment-1869747
the FC A/C and FC A/C (both of them) are idle settings used for when the A/C is on in the car. Each setting is for voltage load and no voltage load ie: lights on and demister. Those settings on the normal FC are 1100 and 1000 respectively so that the idle is slightly higher when you have the aircon and lights on etc.
So I'm wondering if the Pro version simply just has the aircon switch always on, what does it show under SENSOR/ SW CHECK ? How do you select when this "alternate" idle setting is active instead of the normal 700RPM idle?
https://www.sau.com.au/forums/topic/101353-power-fc-pro/#findComment-1869779
no problems. thanks. i guess they just wanted to add that feature with as little as effort as possible. would have been helpful if they had of renamed the menu item. so how do you select when the higher idle is to be active ?
https://www.sau.com.au/forums/topic/101353-power-fc-pro/#findComment-1869797
this is more simple... its just by the IDLE A/C off/on ... there i can choose what revs i want the car to idle when warm...
but since i have the RB25 wired in my s13, i made a compromise between when A/C is ON or OFF because i skipped the ECU when wiring the A/C... so currently i am happy with 870 as idle...
nico
https://www.sau.com.au/forums/topic/101353-power-fc-pro/#findComment-1869819
normal fc users cant set the fc a/c on/off values higher but with datalogit they can. i will test some time this week if the same functionality is achieved by editing the rpm value with datalogit and then manually activating the aircon relay without turning the aircon on
https://www.sau.com.au/forums/topic/101353-power-fc-pro/#findComment-1869848
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
