i have sold my r33 gtst now and have a fair few spare parts left over...
a series one alternator.. works fine was in car runnin around 13-14volts $100
blitz radiator cap $40
standard side blinkers $25
malpassi black fuel regulator, used bout 200km(went for bigger injectors) comes with nissan fuel rail elbow sold
standard brake lines.. no cracks upgraded to braided lines $100
standard injectors x6 worked fine in car but needed more $250
standard exhaust cam wheel $50
standard intercooler comes with few pipes see pic sold
standard ecu series 2 engine no probs works fine sold
i am open to offers, i would rather pick up on the heavier items but will post all items at ur expense items located in post code 2225 so u can work out ur own postage costs.
pm me if any more questions thanx derek
post-20159-1136875512.jpgpost-20159-1136875633.jpgpost-232-1124417991.jpgpost-20159-1136876026.jpgpost-20159-1136876065.jpg[attachmen
=17845:attachment]post-20159-1136876242.jpg[att
chment=17846:attachment]
Edited by dezzabye123
https://www.sau.com.au/forums/topic/101379-r33-gtst-parts-sale/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
