Hi Guys,
I am building up a Series 1 RB25DET that i bought to put into my Datsun 240k. I am looking to buy the Nissan VRS kit or the full nissan kit (as i will eventually do an RB30DET conversion).
I want to ring up nissan tomorrow to order a kit, but this is going to be difficult because i don't have a corresponding VIN number i can give them.
does anybody know for sure what the nissan part numbers for both the VRS kit is and also the full kit for the Series 1 RB25DET (Manual)
and if failing that, would anybody with a Series 1 GTST mind PM'ing me their VIN number so i can order the correct parts from nissan tommorrow?
is there a difference between S1 and S2 kits?
thanks
Kent
and the full kit part number is 10101-17U26 RB25DET Gasket Kit - Engine Repair
it contains:
1x Gasket goo (150g)
1x drain plug washer
1x cylinder head gasket
1x crankshaft rear oil seal
24x valve stem oil seal
1x rocker cover exhaust gasket
1x rocker cover intake gasket
2x camshaft oil seal
1x crankshaft oil seal
1x intake manifold collector gasket
1x manifold gasket
1x exhaust manifold gasket
1x oil strainer gasket
1x oil pump gasket
1x throttle chamber gasket
1x soeal o ring
1x AAC valve gasket
it contains:
1x manifold gasket
1x oil pump gasket
1x soeal o ring
1x AAC valve gasket
What did that end up costing?
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
