Item: 1996 R33 GTR Vspec Series 2
Item Condition: Excellent
Reason for Selling: Need to free up some money for a house
Price and Payment Conditions: $42000 ono
Extra Info:
Engine:
N1 oil pump
TRUST Type R BOV (plumbed back)
TRUST Sump Extention and baffles
TRUST Enlarged Front Diff cover
TRUST 16 row oil cooler and filter relocation kit
HKS Dump pipes
HKS dual Dragger Exhaust
NISMO Engine and gearbox mounts
NISMO S-tune panel filter
NISMO oil/air separator
NISMO oil cap
NISMO Fuel cap.
Suspension:
Rebuilt and revalved Apexi T-max coilovers with king springs (F - 400lbs, R - 225lbs)
Cusco adjustable caster rods
Cusco adjustable rear camber arm
Whitleine front camber bush
Whiteline pineapples
Cusco brake master cylinder stopper
Braided brake lines front and rear
DBA 4000 series slotted rotors front and rear
Hawk pads front and rear
BBS LM 18x9.5" Rims
265/35 Yokohama ES100 tyres
Exterior:
NISMO clear side indicators
NISMO carbon wing end plates
400R Clear front indicators
Tint.
Interior:
UAS GTR seat covers
NISMO GT shift gear knob
HKS Type 1 turbo timer.
BRANT Nemisis
ICE:
Pioneer headunit
Pioneer 6" front speakers
Infinity kappa 6x9s
Custom rear self.
I imported this car 2 yrs ago, it was an auction grade 4.5 car and had 56xxxkms on it at that time. It now has 85xxxkms on it and they have all been trouble free. My modification path has tried too make this car as reliable as possible and to improve the braking and handling. Its probably a good platform for someone to chase HP as it is probably the only area that hasn't been touched yet, it is fast enough for me
The car has been serviced at least every 5000kms using Motul engine oil and Motul Brake Fluid. Gearbox, transfer case, front and rear diffs are using Redline oils.
Anyway, this is a VERY reuctant sale but I am sure in the not too distant future I can jump back into a GTR.
Contact Details: [email protected] or 0400737044
I have a lot of the stock bits still laying around still and also a 2nd set of BBS LMs in 17x9" with Dunlop DO2Gs 235/45 which can also go with the car if wanted.
Some Pics
https://www.sau.com.au/forums/topic/101383-fs-96-r33-gtr-vspec/
awww man!!!!
this has to be my most favourite street gtr... (and the most reliable too)
jason has always looked after her, and never cut corners in getting nothing but the best done...
immaculate condition, never been boosted, and looks like it has just come off the showroom floor.
good luck with the sale dude :unsure:
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
