  • Replies 75
woohoo, just made 370+rwkw on 23psi, pump fuel, at boostworx, looking good for the nats:)
Rb30, 850hp gt42, mv electronic jatco auto
I'd say at minimum you'll be needing a Super Street Licence (11.99 and under) and a tailshaft loop-not to mention some slicks or drag radials.
Good work.
ha,ha, yeh i know, i haven't got time to cage it either,
it made 378rkw and 640nm of torque in todays 42 degree heat
11.5 a.f ratio at peak power.,23psi, pump fuel.
I actually drive it around with rag style Et streets on the road, pointless otherwise.
see what happens, good to see we are now both pushing mikes electronic transmissions
to the max!
cheers
darren
I will have my R33 GTS 4 door out there to have a crack at an 11 second pass this year to improve on its existing 12.5. Trying to do it in full roadworthy regency approved trim too with stock GTR exhaust, airbox, filter etc. (just passed full engineering inspection last week). Just a nice tune up with our laptop Power FC software and 1.0bar of boost through the RB26 should do it :mellow:
Edited by Martin Donnon
heya martin, hows the progress with peter going on starting to work on 4WD's. ive just got a 99patrol turbo diesel wouldnt mind using it as a test mule if he/u are keen to try some stuff
cheers matt
I suppose its easier and cheaper to just dream it eh?
Always is:)be good to see anyway.
MattR throw a ls1 in it:)
Yeh i have heard that the timers may not be fixed in time, rumour mill in
real life and the internet is going crazy...time will tell i guess
cheers
darren
Trying to do it in full roadworthy regency approved trim too with stock GTR exhaust, airbox, filter etc. (just passed full engineering inspection last week). Just a nice tune up with our laptop Power FC software and 1.0bar of boost through the RB26 should do it biggrin.gif
Hmm.. full regency approved + power FC... 1.0 BAR of boost.. methinks I smell a contradiction :)
I called and asked what mods are street legal to cars the other day.. and the lady said, you can have a different exhaust so long as it's not too loud, and you can have a different intercooler + piping. Cams, turbo, fuel computers, turbos, basically anything that can make a real difference to power need to be emissions tested (3 grand, thank you very much) to see if they comply with ADR's. Basically.. err.. what was my point? Oh yes, completely street legal + 11 seconds.. I doubt it's truly possible, even in a car as mighty as the GTR... If you can do it, I mean pass a roadworthy AFTER you run an 11 second pass.. I will bow to your awesomeness!!!
Actually that would be a good way to stick it to those regency goons, try to get some fairly normal mods emissions tested, so we can all have bigger turbos etc. and have an engineers cert for it? Maybe as a group buy? :lol: We can all put in fifty bucks and put it on someones car and get it passed... ah but I bet that they require testing for each individual car *sigh*.
Hopefully my honda s2000 will be ready by then. I can't wait to get into the low 11 or better. However with the rate of work done on the car I don't think it will be able to get out of the workshop early enough for De and I to pull the head out and check the engine before 4,6&R :P
Surely they wouldnt cancel the event (outright) due to timing equipment issues? Postpone maybe, but not cancel! I certainly hope not. I'm on target to have a 'slightly larger' new turbo and manifold combo in and tuned... but a delay in the event wouldn't hurt :D
Congrats on the R31 results Darren. Shaun was telling me it's a bit hard to tame even on the ETs! Fill it up with 110 and there's 400+ to be had.
G'day Martin. You must have a new mob' or too busy at the moment? I sms'd you the other day (re a Feb06 Hot4s hose article - 'Can you write in to tell us the odd part out, though?') I can! And most of the 'odd parts' are long gone :)
Hey Matt, if you can do better than 12.74 in the TD Patrol I'll buy you a beer mate - make that a carton :O
Hard to tame....you could say that,
with et streets rags, let down to 15psi on the high boost,(23psi) it does a top fuel
style burnout in 1st 2nd and straight into top gear :rolleyes: , hopefully
gearing it up a bit helps alot. I thought the tyres were better than that :P
cheers
darren
sorry to be the bearer of bad news, but a little birdy told me that they had been either cancelled or posponed due to some timing equipment issuses....
could be bullshit... not sure
Just reading on Ausrotary.com the nationals looks to be cancelled & its more than just equipment issues :D.
doesn't mention it on the air website though?
heres a email i just received from AIR. [email protected]
As of yet the meet has not been cancelled. I have been told by management that hopefully our timing system will be repaired by then. I will be able to give you a definite yes or no on the 8th. We are flying in an expert from Melbourne to analyse the problem and hopefully rectify the major problem we have with our timing system.
Regards,
Trish
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
