i currently have a r33 s1 gtst with a cat back exhaust,pod filter and bov i was wandering what would be best do do first i was thinking of getting a front mount intercooler however i was wandering what i need to do to get a full turbo back system i dont know much so any help would be great ive been reading around and dont understand a whole lot :blink:
My list would be
1. Coilovers Or springs + shocks (can get d2 for about 1500 install in perth)
2. Heavy Duty Clutch ($800-$1000 install)
3.full exhuast ($1000-$1200)
4.Fmic ($250-$300 for a china-cooler and about $500-$600 for piping)
5.Rims (anywhere from $500 to over 2k)
An exhuast system in a turbo car goes like this
Turbo --> Dump --> Front Pipe ---> Cat ---> Tip
so basciy u have the cat-back which means to get a turbo back system u will need to buy a front pipe and dump pipe.
You can get a Dump and front all-in-one pipe for around $300-$500
-I think rims are important not becuase they make the car look good but they increase the size of tyre on your car which helps with traction, and most of the time when you get rims you buy good tyres too
How much are you looking to spend?
Cheers Michael :blink:
well i hav 17's with brandnew rubber the rims arnt special but i guess there sumthing and the suspension i bought the car from paul at autoworx and he told me the suspension was a racing type which were adjustable from what i hav felt its very hard sorry for my lack of knowledge im still young
npz sammie :blink: we all start somewhere :)
here are link to a dump + front pipe
http://www.skylinesaustralia.com/forums/in...showtopic=74022
also check out http://www.skylinesaustralia.com/forums/in...p?showforum=141
as there are alot of Business Traders which supply the parts your looking for.
are you from perth?
and maybe u could help me with another question i been wanting to ask but havnt posted yet, im confused with boost how it works and what boost controllers do and how people talk about 7psi,12 psi etc and how they can adjust it
if you can take a photo of the suspension tops, or the suspension itself (turn the wheel so you can see under the car more)
FMIC, will not really give you more power by itself, it will allow you to run more boost which in turn will give you more power
i say go for getting a full turbo back exhuast system and you should gave abit of power
ok i give this one a shot, im not an pro so it may not be 100% correct but should give you an idea;
a turbo compress the air flowing into the engine, so you can get more air into the engine.
Boost is basicly the compressed air being pushed into the motor, so the more boost you run the more compressed air being pushed into the engine BUT that doesnt mean you will be getting more power. each turbo has its own Efficiencies range, which for a rb25 turbo is around a max of 12 to 14psi once you go over that the turbo will not make anymore power or you risk blowing it up as the wheels inside the turbo arnt steel.
A boost controller controllers the level of boost, you can get Electronic boost controllers or Manual ones ---> EBC you can adjust the boost lvl inside the car and manual ones you have to open the bonnet and turn it
michael
alrite thanx alot um mayb in a private message or on here u could maybe explain to me about boost how it works etc psi and stuff ?
i see what else i can think of and send you a pm later tonight :blink: i uses to be a young sauwa member and i remember how much there is to learn about turbo cars and skylines and how hard it can be at times :)
after reading through some guys alot of people recomend to finish off my exhaust do you think this is a good idea ? iwant something to give a little bit more power and does anyone know roughly how much a dump pipe and a front pipe will cost me ?
great well im defintely considering buying the split dump and front pipe from the link above im not sure if i hava high flow cat i will have to speadk to the dealership where i got it from but i will do that first get the front and split since it will give me some kw's and i was wandering how come batmbl is selling it for so cheap ? i was looking at the xspeed site just a normal hks front pipe is around $600 and a turbo dump pipe is around $450 ? any reason why batmble is selling for so cheap ?
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
