Hey people
Wrecking Entire R32 GTST. Its a 1992 model, Gun Metal Grey.
Passenger front damage.
Drivers side front guard is ok. Rest of body is ok inc drivers door. bootlid, rear bar, tail lights etc.
Entire interior ok. (Drivers seat has small rip)(rear seat has cigarette burn :blink: ) (no middle vent. hehe (broken) :) )
passenger front suspension items are no good.
rest is fine inc control arms etc.
PM Me asking for anything you need
for quickest reply Email me on [email protected]
Not really trying to get massive dollars from it. its more just to get rid of it. so most offers accepted. (Unless completely rediculous e.g. $2 for whole interior :( )
Car is located in Bayswater, some bits are with car, some bits(interior) are at my house (Croydon)
Happy to post smaller items (not that i can really think of any) but rest is pick up only. or delivery could be arranged if not too far away :)
Cheers people :)
Pics also avaiable if completely nessacary. :)
Edited by Memph
https://www.sau.com.au/forums/topic/101428-wrecking-r32-gtst/
  • Replies 78
Hey people
Entire interior ok. (Drivers seat has small rip)(rear seat has cigarette burn :unsure: ) (no middle vent. hehe (broken) :D )
Not really trying to get massive dollars from it. its more just to get rid of it. so most offers accepted. (Unless completely rediculous e.g. $2 for whole interior :) )
Cheers people :)
please email pics to [email protected]
Steering rack is no good, sorry
Car was manual, so i guess that makes the climate control unit no good to you. sorry ;(
The car is currently at the mechanics have the motor taken out. so i cant get pictures of the body just yet.
I have done my best to reply to all emails and PMs.
If you PM me, could you please put the item in question in the title :) cheers guys
i have about 20 PMs all just with R32, Car, Wreck, etc. hehe :(
Would just make it a little easier to sort though
Thanks again
Steve,
In melbourne :P
Sorry, Should have mentioned, I'm not going to sell any parts of the motor just yet,
The motor came out of the wreck today as its going into my new car.
So i will have a Full RB20DEt, Gearbox, ECU and Loom for sale within the next couple of weeks :P
Cheers
Grren s13. i think i might hang onto the loom. i have a few people interested in entire manual conversion gear. sorry buddy :O
air con compressor i tihnk ill keep with the motor untill it comes out :blink:
Cheers
    • Half anticipating the next question then: I have two magnets stuck in my oil pan. What should I do?
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
