  • Replies 78
after a full set of skyline floor mats, if you have any could you send pics to [email protected]
cheers
Sorry mate, dont have any :)
have u still got the left hand side aircon. vent?? please let me know and give a quote.
girlfnd32    :)
Nah :) all my vents were broken too. lol. i heard you can buy them new from nissan? anyone know if thats true? how much?
Cheers guys. all PMs replied to i think :)
Steering wheel isnt in the best condition. but yes i have it and its here.
lol :P
Just a note that this seller is genuine and trustworthy.
I have had a successful buy from him.
Thanks for that mate
take it the cable went in ok? :P
I'm after an afm, airbox and radiator. Also need the covers for the back of the headlights for the highbeams. Please post or pm a price and ph no. I will need other little pieces but I need to go over the car more carefully.
Can u post up a pic of the wreck?
The wreck isnt at my house (no room for it here), so i cant really get a pic too easy. ill try some time tonight
Do u still have the Front Brakes? (Calipers and rotors)
I have about 4 people interested in the brakes at the moment, so seemingly they are as good as sold. sorry mate :)
Afm = sold, im going to keep the airbox, and the radiator is here :) except the top hose barb is snapped. it still works fine. but its about a centimeter shorter than its meant to be. it doesnt effect the use of it at all. so its up to you :)
feel free to gimmie a call on 0404049723 if you wanna organise a time to come round and have a squiz at some bits and peices :)
Cheers
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
