Okay simple but stupid question! Where the Feck is the horn located under the bonnet! I have a boss kit fitted and all wiring is connected but i ain't got no HHHHOOORRRRNNNN! <_<
It has never worked since day one so me thinks it has been removed....thus why I can't find it under the bonnet!! :unsure:
If someone can take a piccy or a good description of its 'standard' location, it would be greatly appreciated! :D
Cheers,
Ando
https://www.sau.com.au/forums/topic/101441-dude-wheres-my-horn/
oh... now i don't feel like such an arse lol!
in my gtr, in the engine bay there's the little black fuse box, open that and there's a big one for the horn (says on the inside of the lid what is what... other than that i don't know if there's more that it's liked through.
maybe one on the inside of the car for the button as well?
Dave.
Okay well it appears as i suspected....I have no horn! I have didly squat sitting behind the grill in the shape of a horn (UFO).
Now next question.....ne1 have any ideas where i can source one?!
Also does anyone know if those 'airhorns' are acceptable....bring on the Dukes Of Hazard horn!!! :P
Cheers,
P.S. Sorry to hear bout ur GTR Dave (DJ984)!! Best of luck getting it back
Thanks mate, appreciate it.
hmmm, you should be able to bolt any car's horn on there but i don't think air-horns are a legal replacement :rant:
then again... if you mount them low and hidden who will know - the way they work usually is the longer you hold it, the more of the tune that plays. so when you go for a pink slip, they're just gonna hit it for a second and get one sound... thus not knowing is a musical air horn :O he he he
other than that, any wreckers should be able to supply you with the replacement parts.
Cheers for the info mate. The car isn't going anywhere for a month or so now as awaiting funds for some serious modding, so may have a hunt around for a 'horny' replacement..... :)
Question thou....can u rig up a 'normal' horn to ur steering wheel, then have say a 2 way switch on ur center dash say for an airhorn?? Best of both worlds!
Cheers,
Ando
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
