had my rb25 turbo installed today but it lagged alot, so i got it home and put the rb20 actuator on and it is around 7, 7.5 psi, before it was 5psi with the rb25 actuator, i have read alott saying this will work, is the psi ok for this,will i lean out with this psi? thanks
Edited by kit05
ok, well rb25 actuator should be 7psi stock..
rb20 should give you 10psi stock, and that is what it gave on mine.
You are running aftermarket dump pipe, cat, and catback right? A restriction in there will stop you developing 'full boost'
It's quite possible you have a boost leak or something like that.. causing boost to bleed out somewhere, and resulting less in low boost levels. This will also cause your turbo to work harder/heat up to give that small boost level, which is not a good thing. So I'd check it out fully before going to nuts on it.
rb25 actuator is 5psi actually.
the rb25 has a ecu controlled boost control solonoid that bleeds air to reach 7psi.
wizard2k (Josh) on here put an RB25 turbo onto his car, no real difference in spool at all, just the RB25 turbo pulls a little harder.
so you have must have a problem somewhere.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
