Hi All
I need your help urgently. I own a r33 gtst s1, and i put the window down today to get fresh air and now it wont go up...i have taken off the panel and no luck, is there anyway to force the window up?? the switch makes a clicking noise but doesnt go up (drivers side) passenger side is fine....PLEASE HELP AS IT LOOKS LIKE IT WILL RAIN AND MY SKYLINE WINDOWS ARE OPEN IN THE CAR PARK
https://www.sau.com.au/forums/topic/101473-help-needed-urgently/
if you have a multimeter you can check to see if the actual window switch is working or not. Then if its just that can short out the connections to at least get your window back up.
Without a meter it will be hard, won't be able to see if you're getting voltage to it or not, to find out if its the motor dead or a fuse blown etc etc. If the passenger side one still works fuse should be ok.
Duct tape some plastic over it if its getting rainy
  • 3 weeks later...
