hi all i have a rb20det cefiro and it just has the stock turbo on it the mods so far are below
stainless 3" exhaust
BOV
Haltech e11.v2
pod
fmic
wat would u upgrade to i am on a bit of budget but still would like a large increase in power.. wat would u all recommend ? :(
if anyone has one forsale as well pm me i am after parts to make the ceffy faster :)
cheers
hal
  • 3 weeks later...
umm... search.
i use a rb25 neo turbo atm. it made big improvement from stock.
generally a rb25 turbo is a good budget upgrade as everyone will tell you.
a question for you. how does you haltech go? what was it worth?
Greylayzur - Mate as most ppl will say, RB25 turbz is best value for money upgrade. I had a RB25 turbo on my ceffie before it blew...then just chucked on a Rb20 for the time being before getting bigger turbo. BIG difference for the money it costs.... :( I would recommend it to anyone!
P.S. Jump into the Cefiro section of this forum and intro urself with some piccies of the car!!! :(
Ando
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
