Item:Various bits and pieces left over clogging my garage!! See pics and extra info
Item Condition:Second hand - good condition
Reason for Selling:I bought a GTR - and its time to let go of bits I'll never use.
Price and Payment Conditions:See Below
Extra Info:Prefer Adelaide buyers / pickup. May be able to ship at buyers cost. So many parts don't want to spend ages chasing up freight costs etc.
R32 Plastic Undertray SOLD
RB20DET Std Front pipe $25
RB20DET Coil Pack cover $40
R32 Type M Front bar SOLD
Factory driving lights to suit $25
Std Stereo $15
RB20DET Water pump $25 (replaced at 100K service still working fine)
Alloy Swirl Pot $100
Turbo lines / Heat shield etc SOLD
R32 Indicators SOLD
RB20DET Std Dump pipe $20
RB25 turbo outlet pipe SOLD
R32 Type M Front rotors $20 (29.5mm)
RB25DET Clutch fan no slop $45
RB25DET Pwr Steer pump $30
RB25DET Alternator $50
Brackets for ancillaries etc $offer
RB25DET Air con compress $50
RB25DET Engine mounts $30
RB25DET Starter Motor $50
R32 Std Fuel Pump $40 (was ok - replaced with r33 GTR pump)
Kenwood Tape head unit / 12 stacker with remote $100 (came in GTR)
Greddy Turbo timer $50
R32 Rims (2xblack 2x silver) + 6 tyres to suit $650 quick sale drift ready
17 inch tyres SOLD
RB25DET Airbox with filter $40
R32 GTST Front brake rotors/callipers/ pads SOLD(30mm)
R32 GTR Std clutch line $40
Suzuki 10/1997 GSXR750 $7000ono
Thats all I have folks - so don't ask fo anything else!! Seriously this stuff is just clogging my garage - no reasonable offer refused (i'll probably even accept some unreasonable offers - try me!) All proceeds going towards the "Save the GTR - make it faster" fund - go on be a part of it!
Contact Details: Reply here, PM me, email me at [email protected] or stand in your front yard and shout - if I hear you I'll answer.....more pics to follow.
Edited by Blue32
"R32 GTR Front brake rotors/callipers/ pads $250 (30mm)"
Ill take these, if u can C.O.D. (aussie post) them to melb for me.
PM me for delevery address.
Thanks
Sean.
im am interested in buying the driving lights and indicators.
if the rotors fit mine(non type M) i will grab them too. :)
damn wish i got the gtr 1's :P
Trying madly to keep up with the PMs people - inbox is smoking. Have replied to PMs - working on first in best dressed so let me know. Come and get 'em with cash or I'll give you account details and once money is in - I'll send them. Thanks guys,
Andrew
PS GTR wheels not for sale!!!!
I'll take the undertray and the indicators if the eyelets up top (where the bolts go) aren't damaged (and if they haven't gone already to that other fella).
I'm local, so can pickup, but first let me know what suburb you're in.
Cheers,
- Ash.
Edited by Oosh
Frt bar and indicators sold thanks Painting Evolutions
Turbo water / oil li nes and heatshield sold thanks Sky30
17 inch tyres sold thanks HR thirty two
Edited by Blue32
Damn it guys - removed the 'GTR' brakes to fit the AP racing ones - thought to myself they don't look like GTR brakes - measured em at 280mm rotors and caliper with ribs on the top confirms I HAVE GTST brakes on my GTR (had!) So unfortunately no GTR brakes for sale - however $150 for the GTST ones!!!!!! ARRRRRGGHHHHHH!!!!!!
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
