Hey Lads,
I got a RB20DET with twin thermo fans on radiator no air con condenser or anything all ripped out when driving my temp gauge reads....60-70 degrees which i think is a little low but once the car starts to sit in traffic it will jump right up to 90 degrees and start to over heating and start boiling the radiator fluid and spitting it out the over flow tank etc....
Im wonder i have a R33 Radiator in my car also would would be the best way of keep my car cool....vents in bonnet.
What about a new thermo stat that opened up earlier what would this help with.....can i please get some good import as with what to do about my position im in.
Im also putting in new knock sensors as mine are dead dont think this has anything to do with the heating issues but.
Thanks.
- Luke :(:):D
Another basic option is to hook one of the fans to a switch and just turn it on when the car is in traffic, i have it for hot nights and particularly warm days, if its gets any hotter than 1/2 then the other one kicks in due to the thermostat. But of late i did have a few issues with the radiator :(
If it's not overheating when driving around, but does when in traffic then your issue is most likley the thermos.
What size are you running and how are they configured?
Ideally you want to get the biggest fan(s) you can fit purely because they can blow/suck a lot more air than a smaller one (davies craig claim that a single 16 can flow more air than a pair of 12's).
Also, the fans can have the blades flipped over and the polarity of the wiring reversed depending on how its mounted. It would be a good idea to check that they have been set up correctly for your mounting style.
And last. Most fans seem to do a better job when blowing air through the radiator rather than sucking it through. If you can mount your fan infront it may help a bit too.
And flush your radiator while you are at it.
Good luck, overheating sucks arse.
I have 2 fans mounted on the frount of my radiator....i think i might need a new thermo stat as car runs on 70 when general driving but over heats in traffic etc.....
Might have a switch to turbo fans on and off for general driving then when slamming it turn them back on.
- Luke
If your really worried about it, take the thermo stat out of the car, and order a new one from nissan... my thermo stat is ruined so i just took mine out as im waiting for it to come from japan,with a few other parts. Car just takes a little longer to heat up thats all... not good for long term, but i figure its better then having the gauge on H the entire time (i.e cooking the engine)
Dayne
Mine does not cook but it will if i let it.....driving around daily its cold but not in traffic....i think i need a thermostat to make my car run hotter at like 70-80 degrees normal driving and for it to stay under 100 when i smash it.
- Luke
You're absolutely sure they work when the engine's running? And you're absolutely sure they BLOW air through the radiator?
I doubt the thermostat has anything to do with it overheating. If it was going to overheat, it's more likley to do it when the engine is working hard, not when it's just sitting idling.
The standard thermostat is supposed to be around 78C, IIRC.
Err..... have you changed the radiator yet or had it checked out yet? My mate had the same problem. We ended up changing the thermostat, water pump, timing belt, reflushed the cooling system and check the thermo-fans before we changed the radiator. I work at a delearship and the first thing you should do if you have overheating issues with those symptons should be to replace the radiator or have it fixed.
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
Ă—
Ă—
