valentines day suggestions
My gf and i boycotted valentines day a few years ago on principle...
These days its is just a big marketing campeign to get everyone to spend money on roses/dinner with rediculous markup. The commercialism takes all the intimacy away...
We'd rather do things when we feel a time is significant..
Besides.. our anniversary is not long after v'tines so usually do something special then of course... :D
anyway.. all this is IMHO. :)
Originally posted by akeenan
sounds like someone is looking eh??? ! :)
check out this link :lol: :lol:
http://www.skylinesaustralia.com/forums/sh...&threadid=10078
Aww, you don't have a valentine? I feel for you, I really do
:lol: :lol: :lol: :lol: :lol:
but if you want to take me out for dinner I'm not complaining :D
Originally posted by MissS13
I'll be honest.
Valentines day is just a competition to see who gets the biggest bunch of flowers in the office.
Bugger it..
I was reading in the paper today that a dozen red roses will set you back $150!
yeah rose prices are rediculous.. but its not just that.. its all the commercialism and 'pushing' that you/I/everyone have to do something on this particular day.. all the marketing and hype - i just got over it all at some point...
DR GTR said it.. why wait.. do something special when you feel like it and its relevant to your relationship for whatever reason :rolleyes:
ed: on nice places to go all year round .. a great thing to do is to just get that entertainment book .. heaps of good recommendations ... ever got one before ?
anyway.. all this is IMHO. :rolleyes:
Bro that is a mad excuse if you forgotten or had no time to go out and buy prez....
believe me i would love to forget about it.. problem is come feb 14th (and a few weeks prior) the event concept is politely rammed in your face :P
heheheh.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
