Hey there
Just a quick question, i recently bought a new turbo for my Ceff, the turbo in question is a Rx7 Series 4 front Compressor housing and plain bearing core with a rb20 turbine housing on the rear, it also has the Rx7 steel wheel too and the rear housing has been machined out to accomodate the exaust turbine.
The turbo was quite cheap so i bought it thinking that i could put it on myself and hoping that it wouldnt turn the RB20 into a lag beast.
I was just wondering if anyone else out there has dome something similar to this, what power they got, what the boost response is like, if the Rx7 hitachi HT18 (i think) turbo will actually be any better than the std RB20 one?
Also recently i had my car tuned by Dr. Drift (Sam) which was great as he tuned my std ecu and got all the A/F ratios all sorted out. only problem is that my knock sensors arent working correctly (i think) so he ended up tuning my knock fuel map instead of the normal fuel map as the ecu was always picking up a knock event and swapping maps to the knock fuel map.
My problem is that my car has started running rich again (lots of black smoke under accelaration eg running rich as it was before), i thought this might be to do with playing around with the knock sensors and maybe getting them to work again?
would it be possible to unplug the connections on the knock sensors to get the ecu to continually trigger a knock event and swap maps to the good "tuned" knock map? or can i just unplug the knock wires from the ecu to get it to swap maps? or will it just put the ecu into a different "safe" mode and not make any difference
Here is a dyno chart of before and after results, and it also shows off some of Sam's (Dr Drift's) great work
http://i3.photobucket.com/albums/y65/Ceffy_SA/Scan10001.jpg
Sorry about the long post :huh:
https://www.sau.com.au/forums/topic/101592-turbo-and-knock-sensor-question/
Sounds like a typical band aid solution... it's like putting stickytape over a red warning light. Oh well.
If it's a daughterboard open your ECU up and make sure there's a rubber hose or something jamming the chip into the daughterboard or it'll fall out. I think they use hope to hold the chips in in Melbourne.
When it falls out it'll run rich.
Unfortunately its all we could do at the time, i know its not the best solution, but it will do until i get the knock sensors fixed in the future. i just want to get the car running on the good tune again.
I will have to have a look in the ECU tonight to see if anything is wrong.
Thanks someonestolecc
I know what you mean Ceffy_SA. I wasn't having a go at you, just that there are 2 types of people who work on cars.
Those where anything will do (or they just plain suck).. Typically their cars fall apart after some time. Then there's the other type of person who would work on their car as if it were their own, do a good job and end up with cars that function for longer than just the test drive.
I can't say what I would say because you're not meant to bad mouth businesses even if it's fact (in which case it wouldn't be defamation) on this forum.
I'd say 99% it's because the daughterboard has been installed dodgily. Hope it is - cheapest solution to fix it :D .. Good luck and let us know how ya went.
at the time of the tune was sam turning off the sensor and the car was running fine??
Hey there
Sorry about the long post :D
Ahh, i dont think so, i think he just burned the good tune onto the Knocking fuel map, and the A/F ratios acutally got better. No matter how much fuel he took out of the normal fuel map made any difference to the A/F as my ecu was always running on the knocking fuel maping
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
