  • Replies 41
yep sure
me and most of Hi>PSI are interested in something for 2moro
we're thinking
Meet at: Homebush P6, 8:30 pm for a 9:00 pm leave
Destination: We decide on the night. City? Palm beach? Cronulla?
Lets make it happen.
on second i probably had the worst city experiences out of all of you (3 times exhaust system defect)
lets just meet up and see how the flow goes...
make it unorganised and spontaneous lol
Haha, did it involve paying $3 to go through the tunnel, turn left into Wooloomooloo only to get defected? :P We didn't even get hot-dogs!!!
Ah well, the 4 of us had fun chatting away with the Po_lice!
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
