Anyone?
My turbo is a little poorly. :goddam:
I wouldnt mind knowing if the GTST t28 is similar to the GTiR one...
GTiR T28 turbo.
T-28, 60 trim 60 mm BCI-1 compressor in standard T-3
housing. 79 trim 53.8mm Inco T-250 turbine wheel .86
A/R turbine housing
ThankYou
https://www.sau.com.au/forums/topic/10163-r33-gtst-turbo/#findComment-159691
I'll give you what I know.
The R33 (and R32 for that matter) has a turbo which has a bolt pattern of a T3.
So it will NOT bolt on to a car that had a T28.
The internals are of a similar size to a T28 though.
All I know about the sizes is that the exhaust wheel is 48mm for the R33 and 42mm for the R32.
But ALL skylines GTST from R32 onwards, have a T3 bolt pattern.
Not sure about the R31's and earlier..
The GTR's have twin T28 turbos. the bolt patter is a T28.
However, they are only good for twin turbo set ups.
The T28's on the GTR's do not work that good in a single turbo application.
WRXKILLA...
Just incase you didn't know.. the skyline turbos have ceramic exhaust wheels.. so I doubt that they would be an upgrade for your GTiR even if it did fit.
https://www.sau.com.au/forums/topic/10163-r33-gtst-turbo/#findComment-159798
Nope,
The GTiR turbo will take excess boost pressures.
I know many GTiR owners that have run 18psi and even 20psi on the stock turbo for long long periods of time as daily drivers and never had a problem.
Of course it isnt exactly efficient at those pressures. But hey.
My Mate Ivan ran a 12.3 with stock turbo stock pretty much everything. 20psi.
My car came back from a Particular workshop withthe turbo buggered. Bit suspicious. Considering I had a lot of other things done wrong too.
But I was running 14psi.
https://www.sau.com.au/forums/topic/10163-r33-gtst-turbo/#findComment-160925
nice...
did you go back to the workshop to complain or anything.
yeh the Gtir turbo's don't have ceramic exhaust wheels so no problem with running over 14psi.. but like you said, above that and it starts to get out of it's efficiency range... especially with the top mount interheater that they have.
https://www.sau.com.au/forums/topic/10163-r33-gtst-turbo/#findComment-160998
he he he, yep, gotta love the Interwarmer, I cooked Bacon & Eggs on it once! :D
Yeah, Umongst other things, They Cross Threaded an Intercooler bolt and ross threaded the thread inside the plenum, (where it bolts in), left a gearbox bolt out!, replaced my Nissan Oil Filter will a Coopers!, I now get some clunking noises from drivetrain since the day it came out, and of course my turbo is a littel buggered since it came out.
I think I mentioned in another thread somewhre which garage this was.
In Sydney's East.
https://www.sau.com.au/forums/topic/10163-r33-gtst-turbo/#findComment-161051
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
