So im sittin outside the commerce/buisiness section waitin for my friend to pick me up right..... When all of a sudden heaps of really hot chicks in short skirts start turning up! Pwoah! I said hi to a few, but dammm....... so many at once =O
better than teletubies ryan ???
my avatar is kristin kreuk
oh man
this class sucks
check this:
2003 TEST 1
Open WordPad
Type the following in Arial, size 16:
I am the greatest person in the world.
I am going to pass all my exercises and tests and become the world’s greatest PC nerd.
Then type your full name in Arial, size 26.
Save your document to A: as 2003 TEST 1
Print a copy
Hand in your printed copy and your disk for marking
its lke going back to preschool
:bahaha:
2003 TEST 1
Open WordPad
Print a copy
you are kidding right... you just made that up?
    • So there is no other way to remove and install the ball joints then to buy the Frenchys kit?
    • Just to close off this post with the cause of my oil consumption issues. Vertical scoring and glazing at the bottom of cylinder 6. I'm not happy, but at least I finally found something. I'll pull it and get it apart asap. Hopefully I don't need to go one size up in piston.
    • I finally got around to purchasing an actual articulating borescope. Great tool to have, I've been very impressed vs my old regular inspection camera.  With that being said, sadly I finally found the cause for my oil consumption. I always had the feeling something wasn't right but compression and leak down tests were always perfect and I had already inspected the cylinders. This time i dropped each cylinder to its absolute lowest point and with the better quality camera I found this... Bottom of cylinder 6.  Scoring looks deep and I'm presuming oil getting by caused the glazing. I already spoke with my assembler, and will be dropping it off as soon as I can pull the motor and get it apart. I'm just hoping it's not deep enough to require boring out from 86.5 ->87mm. Pistons aren't cheap.
    • I think it's the same. It all comes from the same shithole refinieries in SE Asia.
    • I was referring to the final octane level achieved once 10% ratio of ethanol is added.
