WHITEPRINCESS : just my opinion, probably ur mechanic knows the problem, but said O2 was faulty so he charged u more, and fixed the lil problem caused ur rough idle.
Rough idle could be lots of things,
Dirty Air Filter, AFM Conection?, or Spark Plug etc,
Clean them and see what happen?
To reset eCU...Instructions:
- FUSE box driver side kick panel, (remove it)
- look under, u should see a grey plug,
- there should be 2 wires on its own,
- short circuit it for 2 second,
ecu should be reset, check for engine light flash.
Hope it helps,
cheers,
darrien
also want to check your aac valve mine was idleing a bit rough doin thatup and down thing sometimes when i stopped at intersections
i ended up pulling the connecter off the aac valve and idles smooth as
i have also replaced my o2 senser and spark plugs, only because my car was running rich as, but wasnt really the cause of makin my idle go all stupid
the guy was quite honest about what he was doing. i saw what readings he was getting on his diagnostic computer before, it was showing the O2 sensor readings 0.01~0.03 and that's not right - i also have r33 engine manual that confirms that O2 sensor should be giving out something like this 0.3~1.0 from what i can remember. also one other sensor was always saying 'rich' where it should be changing to 'lean' when the car was reved... i know for a fact that when i came in my car was stalling here and there, i saw the guy installing the O2 sensor (no hidden magic there) and when i drove out of the garage 20 mins later, the car was running perfect...
thanks for your feedback though :)
i guess my recommendation would be to find a person who can connect up a diagnostic computer to YOUR car, read the reading and understand them so then they will tell you what's wrong with the car... becuase rough idle can be caused by many things as many people said, in my case it was O2 sensor but on another skyline it could be dirty something or rather etc etc.
  • 4 years later...
Thanks for the info guys. I've been searching around and seems to be the AFM. One other thing i should say is if i open the oil cap while the car is idling, the idle drops quite a bit and the car sounds like its going to stall? Vacuum problem maybe?
I noticed this the other day on mine. Is this Normal?
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
