tube and fin vs bar and plate
54 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
ok guys i need your advice. i want to fit a fmic to both mine and my sons r33 gtst skylines here is the problem i am faced with. what do i buy do i get a bar and plate or a tube and fin intercooler is there any advantages or disadvantages with either cooler im so confused the more i search the more confused i become my head is starting to hurt :rofl: also outlet size is 3 inch the way to go or 2.5 inch both cars only have exaust 3 inch cat back. pod filter. what type of performance gain can i expect going fmic over the stock one?
https://www.sau.com.au/forums/topic/101690-tube-and-fin-vs-bar-and-plate/
there are also many different types of bar and plate / tube and fin. The way the tanks are made and set up make a massive diffrence on how the air will flow through the core. (wish i could find the site i got this from) The 2 main types are not better or worse then each other both are used for differant applictions. Just make sure you get one that is a known brand not the chinese nock offs, even though some of them are actualy good.
What you want to look at it the point at which the tanks and pipes will flow through the core, eg if both tanks and pipes are in the same entry/discharge point you are not utilizing the hole core, the pipes need to be at different points or have some sort of displacement to spread the flow but not impede it. Hope this is some help
All of that was from a full report on intercoolers
Ok the general rule is that bar and plate cool better but are more restrictive. Tube and fin flow better but don't cool quite as well.
Most people put the tube and fin on their skylines because they don't need any extra restrictions, especially with a stock turbo like you obviously have.
I have a tube and fin. Enough said. :P:D:D
Tube and fin was also supposed to have better flow-through to your radiator. I'm sure i read that somewhere.
And yes, what ^he said - better flow through the intercooler core, but less cooling ability compared to bar & plate.
I did a lot of reading on this a while back.
And i also got tube & fin :P
make sure you get one with a good designed end tanks. Its all about the flow through the tank as mentioned. See the std GTR intercoolers for the design im talking about.
i hate the cores that have the inlet / outlet down the bottom.
If you only want up to 300rwkw the GTR ones are more than capable, and are tube and fin = good flowing of air through to radiator still.
Ive got a hybrid of bar and plate / tube and fin. Just thought id add that to confuse you even more. :P
In terms of performance on the street I don't think there is any real difference between bar & plate VS tube & fin. Just make sure you get a decent brand. I'm another one with a tube & fin 'cooler.
"When I grow up, I'm going to Bovine University!"
looks like people are heading more towards the tube and fin design intercoolers.
As said above though its good to have the better designed end tanks thats where im not sure which way to go as the bar & plate cooler im looking at has the better designed end tanks and the tube & fin cooler i am also looking at has the normal end tanks. Seems most people are still going for the tube and fin design with the normal style end tanks is this correct?
cheers allan
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
