Nurburgring !
I think it's the same. It all comes from the same shithole refinieries in SE Asia.
By Dose Pipe Sutututu 路 Posted
I was referring to the final octane level achieved once 10% ratio of ethanol is added. -
How's your first born doing? 馃槢 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 馃槢
Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
