im trying to take off the factory steering wheel in my s1 33 gtst ive taken off the main bolt what do i have to do next ive tried pulling on it and wiggling it a bit but no luck and this is the first time for me any help would be great trying to do it right now
MacGuyver is right, track down one of these steering wheel puller's, I think it is possible to do damage to the collapsable steering colums if you dont -Disclamer on that last statement: not completely sure, something someone told me once years ago, could be wrong, i dunno, but why take the risk?
Yeah I've heard of damaging the collapsable steering columns as well. You should be able to get a steering wheel puller from somewhere like Repco or Super Cheaps, doesn't cost much. Don't try to remove it with out one! And make sure that when you do remove it, the front wheels are straight so when you put the new wheel/old wheel back everything is straight again.
"My cat's name is Mittens."
You can usually get them loose by grabbing the wheel at "quarter to three" and wiggling back and forth (along the axis of the steering column, not like you are turning a corner) at the same time as pulling the wheel towards you.
It is probably a good idea to leave the nut on a few threads to avoid belting yourself in the forehead when it finally gives.
i have an r31
i took a stock wheel off on wednesday
i used a hammer and left the bolt on as you would want to instead of copping a steering wheel to the face
Steering wheel puller
Either side of the centre nut that holds the wheel on there will be 2 threaded holes (one either side).
The puller kits come a main piece shaped like so =0=, There will be a large bolt that goes through the centre of the puller and butts up to the bolt that holds the steering wheel on. Also in the kit will be a range of bolts to fit different thread sizes for the 2 threaded holes on the sides that I mentioned before.
Just screw the two side bolts in so there is a decent amount of thread holding them in and then screw the large centre bolt in until the wheel pops off.....5 minute job.
Hey man what's up.
If your planning on using an aftermarket wheel and hub, let me know how it all went together please. Mainly how easy it was to make the horn work b/c I'll be doing the same thing on my car soon.
Thanks a lot.
Cheers B)
    • Nah, you failed to pay your washer cover subscription and BMW have revoked your access.
    • Haha thanks Lith,  So it's currently working quite well and the torque reduction is setup and working phenomenal. It also got a custom torque convertor from All Fast in WA. Stall speed somewhere around 5500rpm unlocked but still with the lockup. The car went back onto the dyno after a 3yr hiatus (even with the dbw, and other mods completed in this time) managed to make ~515kw at all 4 hubs. Sean setup the Torque reduction which now sounds awesome and working well. We setup adjustable torque controlled launch control aswell.  Man what a feature. Especially when drag racing on street tyres I Managed to get out to the drags late last year and tick a huge bucket list item off of running mine and the cars first 9. Car went a 9.98 @142 Still had the young fellas car seat in the back aswell.  This was on 255/40/17 Nankang AR-1.  Currently the Turbolamik is still completing it's own torque calcs and managing shift times from there. Unfortunately emtrons can export is still a little restrictive to export the ecu calculated torque just yet but I have recently been suggested a work around that I just haven't had a chance to trial yet.
    • Yeah its bad eh. Ey! Watch your mouth. Yep, spot on. The rear's are always gone too though from brake checking. I had them perilously close to a tree that we had taken down. I think the tree peeps may have taken it. Either for a trophy, or accidentally.
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
