im trying to take off the factory steering wheel in my s1 33 gtst ive taken off the main bolt what do i have to do next ive tried pulling on it and wiggling it a bit but no luck and this is the first time for me any help would be great trying to do it right now
MacGuyver is right, track down one of these steering wheel puller's, I think it is possible to do damage to the collapsable steering colums if you dont -Disclamer on that last statement: not completely sure, something someone told me once years ago, could be wrong, i dunno, but why take the risk?
Yeah I've heard of damaging the collapsable steering columns as well. You should be able to get a steering wheel puller from somewhere like Repco or Super Cheaps, doesn't cost much. Don't try to remove it with out one! And make sure that when you do remove it, the front wheels are straight so when you put the new wheel/old wheel back everything is straight again.
"My cat's name is Mittens."
You can usually get them loose by grabbing the wheel at "quarter to three" and wiggling back and forth (along the axis of the steering column, not like you are turning a corner) at the same time as pulling the wheel towards you.
It is probably a good idea to leave the nut on a few threads to avoid belting yourself in the forehead when it finally gives.
i have an r31
i took a stock wheel off on wednesday
i used a hammer and left the bolt on as you would want to instead of copping a steering wheel to the face
Steering wheel puller
Either side of the centre nut that holds the wheel on there will be 2 threaded holes (one either side).
The puller kits come a main piece shaped like so =0=, There will be a large bolt that goes through the centre of the puller and butts up to the bolt that holds the steering wheel on. Also in the kit will be a range of bolts to fit different thread sizes for the 2 threaded holes on the sides that I mentioned before.
Just screw the two side bolts in so there is a decent amount of thread holding them in and then screw the large centre bolt in until the wheel pops off.....5 minute job.
Hey man what's up.
If your planning on using an aftermarket wheel and hub, let me know how it all went together please. Mainly how easy it was to make the horn work b/c I'll be doing the same thing on my car soon.
Thanks a lot.
Cheers B)
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
