Pete selling already???
this is like one of the cleanest skylines going around at the moment iv seen it in person when getting my car serviced and this thing sounds and apparently goes very good for the few mods that it has, my mechanic tells me.
Petes looked after it very well in the time he has had it, and i know it has never been thrashed!!
this wont last people all it needs is rego, for under $13500 you will have a very nice trouble free skyline.
https://www.sau.com.au/forums/topic/101742-r33-gts-t-s1/#findComment-1881380
my mate is interested in this car just posting for him he is after a cheap skyline.
its says well looked after never thashed.he wants to no why it has a hicas lock if it was never thashed.how bad is the dent is it anything to worry about for daily driving till he has more money to fix it
https://www.sau.com.au/forums/topic/101742-r33-gts-t-s1/#findComment-1884863
The dent is hardly anything, its roughly 30cm long from point to point starts at nothing to about 3cm deep at the end right near the tailight
(picture a dent from hitting a guard rail at low speed) the paint is all still on it apart from a tiny bit flaking off at the end near taillight but thats only visable when really looking close. I was quoted roughly 500 when i had a panel beater look at it but thought the money would be better spend elsewhere and never had it fixed,it didnt bother me enough.
The hicas lock is purely because if you have driven an r33 with hicas youll know you either like it or LOATHINGLY HATE IT haha, i hated it so i removed it.
Another thing situations have somewhat changed a little so a update to price
https://www.sau.com.au/forums/topic/101742-r33-gts-t-s1/#findComment-1887064
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
