hi everyone. I was thinking about going to the drags tonight for a bit of fun and was wondering if buying an octane booster to drop into the petrol tank would give me any sort of power gain. i have a previous best time of 13.8 with the same mods as i have now, would half a second off be possible, or would the difference be minute? thanks!
https://www.sau.com.au/forums/topic/101759-octane-boosters/
Well no difference in power but my tuner recommends adding a bottle if I was to do a 1/4 mile run or a dyno comp just for the assurance of no detonation, it all depends on how much power your running I suppose.
https://www.sau.com.au/forums/topic/101759-octane-boosters/#findComment-1866553
There was a thread with this asked a while back.
I uploaded a Zoom article where they tested 20+ octane boosters, only one allowed any extra ignition timing.
Might need to run a search if you want to find the article.
Basically they do bugger all and are a waste of money.
https://www.sau.com.au/forums/topic/101759-octane-boosters/#findComment-1866555
try adding toluene
you will have to advance the time drastically though
and yeah, it can take a toll on your car if you push it to hard
it burns alot hotter than petrol
I have been dropping 8L of it into my tank and advancing the timing to around 40 degrees
but yeah, it does give significant gains
just dont add to much
https://www.sau.com.au/forums/topic/101759-octane-boosters/#findComment-1871845
As most people have said - not for power gain - more for insurance. Raises the anti-knock value of the fuel - protection against detonation.
Fast Fours Magazine did a test ages ago with NF Octane Boosetr Racing Formula and Nulon Pro Strength Octane Booster tieing for first place.
Both raised the RON value by 2.8 points.
https://www.sau.com.au/forums/topic/101759-octane-boosters/#findComment-1872090
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
