Hey guys,
I have recently set a power goal of 200 rwkw for my RB20DET R32. At the moment I have between 160rwkw and 170rwkw. The mods I have are:
3inch Exhaust
ZG30 Turbo
Boost controller running 12 - 14 psi
No A/M ECU yet. Looking at the Power FC.
Besides from a FMIC, what mods should I look at for squeezing out an extra 40kw at the wheels?
https://www.sau.com.au/forums/topic/101782-200rwkw/
remapped ecu, good cold air intake, fuel pump, 3" split dump and get it tuned. i dont think you will make 200 however
What paulr33 said.
#But your 3'' xorst will still be ok as long as it is 3'' from the turbo back.
#Hi flow air filter.
#Remapped ecus are allright.But if you have the money get a pfc.
#Maybee a adj fpr.Becuase at high injector duty you will want constant high pressure in teh fuel rail.I was told this by CRD.
#A hi flow rb20 or 25 turbo and you will make over 200rwkw.
Other than that teh stock turbo wont push beyond 180-190rwkw that easily.You do need all of these,though,if you want to get the max! out of your current setup.You need an upgrade on the turbo.
As you would have allready seen though dynos are conservative to say the least.With many saying their car has 200+rwkw on the stock turbo.When i was at CRD my r33 was tuned to 182rwkw stock turbo with a 2.75'' dump,stock cat and 3.5'' xorst from then on.With all the usual other mods.
I hope your not running 14psi in the heat of the day with that tiny intercooler.After the powah look at the suspension if you havent allready.Then take it to the track and thrash it!!
I am at the point now where i can upgrade the turbo and easily make 220rwkw.
HTH... ;)
https://www.sau.com.au/forums/topic/101782-200rwkw/#findComment-1866474
Ill also get it tuned on Shell Optimax Extreme and see how that goes.
Is that the 100ron stuff? If so i heard it wasnt good for skylines, apparently it only works well in new cars.
I havent tried it though, i just stick with my BP Ultimate.
https://www.sau.com.au/forums/topic/101782-200rwkw/#findComment-1867113
Just an update. I have installed a FMIC and an apex'i power intake. It actually made alot more of a difference than I expected it to! Its alot louder now too:). I am almost ready to order a PowerFC for it. Any suggestions where the best place for one is?
https://www.sau.com.au/forums/topic/101782-200rwkw/#findComment-1904055
hey dude, ive got a 4dr 32 aswell and i made 170rwkw with rb25 turbo, gtr fuel pump, 1bar boost, 3" turbo back exhaust, and shitty hks mushroom pod
no front mount... its on the way though and itll be in the car soon
my point is... get an aftermarket dump pipe!
they do HEAPS
go look at your stocker and youll see that the bit where the wastegate opens goes into a "wall" in the dump pipe... VERY bad design, causes a SH*TLOAD of turbulance when the wastegate opens and makes exhaust gases flow really sh*tty.
also, i assume that by ZG30 turbo, you meant VG30 out of a 300ZX.
if this is the case, go get that hi-flowed.
many people have had good results with hi-flowing that turbo because of its decently large exhaust housing
PS: GET THAT DUMP PIPE!!!
Edited by salad
https://www.sau.com.au/forums/topic/101782-200rwkw/#findComment-1904961
You may want to figure if the VG30 turbo you have is the steel wheeled version. As you should be able to run 18+psi fairly reliably. And with other sensible mods Such as a Good quality split front/dump, Quality cat (a metal one), GT-R injectors, Regulator and PFC or remap there is no reason why you can't comfortably surpass the 200rwkw figure.
Oh and finding a PFC for a 32 can be difficult. "AP Engineering" make em.. don't know why.
This is why so many 32 owners opt for the remap instead. Wich can net very healthy results if performed correctly.
Good luck anyway :P
Edited by Drift_Limo
https://www.sau.com.au/forums/topic/101782-200rwkw/#findComment-1905506
sure r u? have you driven one? big call if you havent.
imo most remaps are just stock tune with fc and speed limiter removed
a remaped ecu(tune by Adelaides Guru) and just a stock wt fcd comp were both tested out on Huddys car both power curves were exactly the same?
oh and VG30 turbo's never came with steel rear wheel from the factory.
Edited by 1400r
https://www.sau.com.au/forums/topic/101782-200rwkw/#findComment-1907651
AS everyone else has mentioned:
FMIC (which you have now)
Apexi air filter (whic you have now)
3" dump all the way through (with a "CUSTOM" cat :D )
PFC is the way to go if you can afford it but there is nothing wrong with getting a ECU remap by someone like Dr Drift, Sams results kinda speak for themselves!!!!
If you want info on the "CHEAPEST" AP Engineered Power FC then PM :)
Other than that good luck with your power figure and hope you get what your looking for...
Cheers B
https://www.sau.com.au/forums/topic/101782-200rwkw/#findComment-1907776
check out huddys thread in the ceffy section
mods needed
fuel pump
exhaust
fcd
2530 or similar
front mount
boost required 1 bar
result 215 rwkw
That sounds like alot, I have fuel pump, 3inch exhaust/dump pipe, gtr injectors, wolf 3d, cooler, and 1bar and Im making 160rwkw, altho my turbo is still stock.
https://www.sau.com.au/forums/topic/101782-200rwkw/#findComment-1910154
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
    • Nissan needs to forget about building SUVs in every size possible and bring back the damn Silvia/200sx duo to compete with the 86/brz. Maybe with the Honda type r motor pointing the right way
    • Good to see you followed your heart, got your dream car and have it pretty well sorted out now. I think anyone can get caught out with a seller not being 100% honest about a cars problems. Can relate to all the electrical issues, had similar issues with my first car (mk2 escort) ages ago
    • I just bought the Nexus S3 for my gtt, haven’t installed it yet as I’m collecting parts to do everything at once…so far spent $14,000 The Nexus is nearly future proof
