Went for a drive down the coast on the w/e. Camera detection pads on only 1 side of two lane road with unbroken lines. i.e pass someone at 90kmh+ and don't get caught while overtaking, or even safer, drive on the other side of the road if your speeding and no camera action.
Thumbs up to the dickflops at the RTA!!!!!
Always.
Its an important part of changing public opinion.
Every do-gooder that see me do it thinks "wow, that idiot knew where the speed camera was and slowed down for it, then sped up after it. They don't slow ppl down at all"
Come on everyone, join the revolution
Yep Pete I chaned the TPS as the consult showed an error code from the TPS mentioning sometihng about the ABS.
I had a go and now the light hasnt come on for 4 days. Even if I sit and idle.
So cross my fingers. I can say when the problem was there it would come on everyday!
DUncan. you legend :P I am going to have a go!
I saw the lines you speak of. They are very faint lines. 3 of them on each lane.
So thats the only section you must pass on the speed limit and after that booommmmmm!!!!!!
It's ok to avoid speeding cameras when you know they are around, but what do you do to avoid losing the points and maintain your perfect driving record once you've been Kodaked?
Easy, just put it on your mum's license and tell them she was driving your beast at 180km. hahah. That's what I did and I'm still on me Gold...haha
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
