I have a 1990 Aussie 4 door R31 that I have spent lots of time and money
on and the time has come to put it up for sale.
Serviced every 5,000 kms, fastidiously looked after, extremely tidy example.
Some specs include:
RB30ET
160,000 kms
Manual RB20 Turbo G/Box
Xtreme extra heavy duty clutch
Lightened flywheel
3 inch 1 Piece Tail Shaft
LSD
Fresh T03/04 Turbo
K & N Pod Filter
Malpassi Fuel Regulator
Wade Cam
Custom exhaust manifold
Custom split dump pipe with screamer
Enlarged internal wastegate
Full 3 inch Mandrel bent exhaust with straight thru rear muffler
Custom Front Mount Intercooler
17 inch BBS Rims
Continental Sport Contact Tyres
Respray in original colour: White over Slate
Lowered
All new Rubbers and Bushes
Dark Tint
MOMO steering wheel
Short Shift Kit
HKS Turbo Timer
GReddy Boost Gauge
Near perfect interior
Full Stereo System
Remote Central Locking
Engine Immobiliser
Reg + RWC
Recent Dyno tune
Plus more im sure I have forgot to mention...
If your looking for a Turbo R31 this is it! All the work has been done for you.
Has plenty of power and torque, yet is still pretty good on fuel and can certainly be daily driven. Has a dyno proven 228rwkw.
I am located in the Eastern suburbs and genuine interested
peoples can PM me for more details and/or inspection.
Email: [email protected]
Asking $10,500
Thanks for having a look.
Edited by ForceFed31
https://www.sau.com.au/forums/topic/101822-vic-r31-s3-manual-turbo-modded-pics/
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
