You've got a remapped ecu that is certianly not tuned for your bigger turbo... There is your problem. You can't hear all pinging. It'll be rattling those forgies left right and center and you won't have  clue till you start seeing blue smoke in the rearview mirror.
Dumbest shit ever.
Go and get your car tuned properly before you kill it.
if you had of Listed your mods to start with, explained what you've done, and didn't be a smartassed prick about it you might have gotten better answers. You wonder why people have got no idea what you're on about and can't help you? Noticed the scattered posts that people have left here with no idea?
Is it just me, or does SAU get stupider by the week?
"Everyone, omg, wtf, I just installed a bigger turbo and my car doesn't ping at 20psi! Whats wrong with it!!!!1111oneone!!111!!"
try reading the question properly! in the future instead of writing just wat is in your head, actually y bother if you just want to be a smartass. The reason i didnt list the supporting mods is cause it has no effect on the ACTUAL question, you just wanted to pick s*%t.
secondly you say "Is it just me, or does SAU get stupider by the week?"
sorry we dont all just sit behind a computer and think we r clever cause we can type we can actually do the mods OURSELFS "mechanically minded" instead of paying a performance shop $$$$ to do it for us,
Edited by EVL032
https://www.sau.com.au/forums/topic/101829-pinging/page/2/#findComment-1880568
thanks you actually offered help!!! :D
With a rebuilt turbo it should be more efficent, meaning more airflow at the same psi of restriction. So actually if it was tuned on map it would be more likely to ping and if on maf same thing but max it out sooner and go into rich mapping to avoid detonation, maybe thats why.
A new turbo wont give you more boost on the same setting, (i dont care who you are) its just a setting to tell the wastegate when to open.
My 2 cents.
https://www.sau.com.au/forums/topic/101829-pinging/page/2/#findComment-1880583
dipshit, I did the mods myself. I don't tune, because I don't have the equipment.
You started off with the smartassed remarks, and you went on about why your car isn't pinging... thats just a dumb question... I know enough about tuning to know that its not pinging for a reason...which is probably good...
you want it to ping... go and fuel up with 91 octane fuel..
Edited by The Mafia
https://www.sau.com.au/forums/topic/101829-pinging/page/2/#findComment-1881386
Do you have electronic Boost control?
if so, it shoudl hold the same boost.
Do you have standard Boost control?
if so, I doubt it would just 7 psi just from changing the turbo.
Do you have a blee valve?
is so, it's probably knacker or have been knocked during the refitting and needs to be adjusted back.
Do you have an aftermarket computer?
if not, your stock computer is doing the rich and retard dance.
More details, or we are all pissingg in the wind, and I don't like getting wet.
https://www.sau.com.au/forums/topic/101829-pinging/page/2/#findComment-1882099
okay iam over it
i dont want it to ping i know that
isnt this a forum where ppl help, so i was just curious as to y????
read the question
https://www.sau.com.au/forums/topic/101829-pinging/page/2/#findComment-1883864
EVL032
We need to know everything about the problem including supporting modifications before we can accurately help.
What you have done is said this
I just put new tyres on my bike.
Then I fell off.
Why?
Please give us some more details.
BASS OUT
https://www.sau.com.au/forums/topic/101829-pinging/page/2/#findComment-1883875
yes but its a little old school its the hks ez
that was set on 13 before changed turbo when turbo went back in and no one moved the dial was at 20psi
the internal wastegate is set at 15psi, but yeh refer question 1
Do you have a blee valve? n/a
Do you have an aftermarket computer? remap
now i got it sorted anyway i got it a 18psi that me happy enough atm, till can re-tune
https://www.sau.com.au/forums/topic/101829-pinging/page/2/#findComment-1883877
The ebc works on a fixed duty cycle to set boost. If it were a 'learning' ebc where you dial in 15psi and it learns what duty cycle required to achieve that boost level at various rpms then it would be a different story.
I think maybe a boost leak has been fixed up in the process. :P
Edited by Cubes
https://www.sau.com.au/forums/topic/101829-pinging/page/2/#findComment-1888463
mmhh yeh i guess so! i agree with that.
yeh there was deffinantly problems before..... but now all good .yay!
I think maybe a boost leak has been fixed up in the process. :D
https://www.sau.com.au/forums/topic/101829-pinging/page/2/#findComment-1895083
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
