R32/r33 Parts
Item: R32 GTSt Front Seats
Item Condition: Mint, You will not find better! (No Marks, Rips, Cig burns)
Reason for Selling: Upgraded
Price and Payment Conditions: $180 for the Pair
Item: R32 Carbon Fibre front strut/tower bar
Item Condition: Good (some rubbing on underside of bar, this cannot be seen when on the car, and will not effect performance)
Reason for Selling: Would not fit under my Carbon bonnet.
Price and Payment Conditions: $60
Item: Interior Trim Panels
Item Condition: Good (trim on rear seat panels is starting to come away, and needs to be glued back on). No Stains, Cig burns etc.
Price and Payment Conditions: $40 for the set of 4
Item: R32 GTSt Fuel Pump
Item Condition: Perfect working condition.
Price and Payment Conditions: $20
Location: All items are located in Nowra (2 hours drive south of Sydney)
Contact Details: PM or phone 0414792608
Edited by Ryno
Item Condition: Mint (No Marks, Rips, Cig burns)
Price and Payment Conditions: $200
Item: R32 GTSt Rear Seats
Item Condition: No Marks, Rips, Cig burns, however Top of seat has sun fading.
Price and Payment Conditions: $50
Item: 3" Hi Flow Cat (Xforce Stainless Steel)
Item Condition: Excellent (Used for only 2 months)
Reason for Selling: Upgraded to 4" Magic Cat
Price and Payment Conditions: $80  Payment pending
Item: 3" Cat replacement pipe/Resonator
Item Condition: New
Reason for Selling: Not needed
Price and Payment Conditions: $100
Item: R32 Adjustable Pillowball Rear Camber Arms and Traction Rods.
Item Condition: Brand new, Excellent Quality
Price and Payment Conditions: $200 for the set of 4
I also have all interior trim panels available (to match the seats), plus the window surrounds available.
pics of pillow balls and interier trim plz and prices
Will those subframe bushes fit a S13?
Yes they will, I believe they fit:
R32, R33, S13, S14, 300ZX
Ok mate,
Consider them sold.. If u still have them that is..
Are u willing to take $70 delivered? I'm in QLD.. postcode:4300
Pm me with your account details.. or if ur willing to do COD that'd be great..
the door trims, mainly interested in passenger door  trim but would take them all , whats the comdition of that trim panel?
Thanks
Hey mate,
The passenger side door trim is perfect, with the exception of this area, which I have had repaired. Because it is on the bottom of the trim (near the speaker) it is hardly noticeable.
Cheers, Ryan
 Share
    • Pretty simple question. I was about to put the transmission back in and thought I pretty much had it lined up when I noticed it seems like the pressure plate isn't flat. I was pretty careful when undoing the bolts both during initial disassembly for cleaning and when torquing them up for installation so this is pretty discouraging. I'm not sure if I accidentally bumped the pressure plate with the input shaft and bent it somehow or if it just showed up this way. Is it possible that there's just something obvious I'm not doing correctly? I'm pretty sure I was extremely careful to make sure the friction discs were seated correctly in the hub, everything lined up, flywheel torqued according to sequence, the little springs all sitting correctly in their seats, etc.  What's the play here? Do I jump straight to a new pressure plate?
    • OK. I can see that being the case. But if you live in the land of "only switching between 4.08, 4.11, 4.36" like most Skyliners, then you never encounter it. Now I perhaps understand why the crownwheel is thicker on some of the smaller numerical ratio diffs. The two stubs being the same (unequal) lengths and just swapped side to side between the different cases is a new one to me. I'm hating Nissan R200s more than ever now.
    • Reason I say this is I have seen broken ones, in drift, drag and even behind a stock Z. I do appreciate most of the time its the synchro's that go.   Trouble with quoting HP is it doesn't really say how strong the box is.  I've not seen many CD00X box's make it past a mid 9(150mph) I have seen about a stock R33 RB25 box's run a 9 too, they all go boom at some point though.   Another clue is they make gearsets for CD00X box's too, wouldn't be a market if they didn't break or have a limit people are going past.   I totally agree it is a strong box, just have to weigh up the true total cost of the conversion vs rebuilding with a good gearset.
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
