All i know is it's a little cylinder shaped thing about 12mm in diameter and about the same high (i could be completely wrong on the dimensions by the way). It has a hollow centre that is shaped to be a tight fit over the ball on the bottom of the stick
ok here;s the picture taken after i removed the rubber bits.
Just a quick question, is the circlip supposed to be loose? and is that bronze looking piece suppose to have that top bit missing?
I'm just running off to the hardware store to get myself a pair of needle nosed pliers to remove the circlip
Edited by lingeringsoul
ok just took the thing apart and had a look inside, this is what i saw....i supposed the plastic ring is supposed to be sitting inside the metal ring?
well it took me half an hour to actually get it out and when I finally put it in the right position, it was going fine. But when I try to put the circlip back on again, it went loose again, could it be that the ring poped out again?
now I gotta make another trip to the hardware store to get a circlip pliers because the cheap 2.75 pari of pliers are losing their teeth...................
Some comments about the first picture:
1) You have -heaps- of little metal filings in there, are you sure you still have all 5 gears intact? I took mine apart like you have only a few days ago and didnt see any metal filings at all (gearbox oil was changed 2wks ago though).
2) The white plastic bush... See how the right side of it (in the pic) is worn back abit but the left/bottom part is worn back heaps (ie its not even all the way around the bush) I dont recall mine (RB26DETT) having any of that. It was a perfectly smooth/square corner not sorta at that angle like yours is.
UPDATE: Finally!!! its fixed, after 2 hours, its finally fixed. The problem was the first time I put the plastic bit back in, I didn't correctly fit it into the ball at the end of the lever, so when I wriggled the stick around, it must have come loose and feel back onto the side again. So this time around, I took the plastic bush out and fitted it onto the ball and then carefully put it back into the metal ring, then locked it up with the circlip. I gave it a good couple of shifts just to test it out and it seems to be fine for now. How it got out of that hole in the first place is still a mystry, maybe the vibration of the car knocked it loose, or maybe it just needs replacing. Well, i'll leave it for now and see how long it lasts, if the problem keeps coming back, then I'll get it replaced.
This has been quite an interesting experience taking the gear lever apart all by myself and see what was inside. My dad used to do it when I was little and I didn't really know why he was so into it. I guess I understand now. Working on it all by myself seems to bring on a sense of achievement which really felt good.
A pair of pliers - $2.75
A pair of circlip pliers - $13.95
Fixing the problem all by yourself - PRICELESS
good to hear you got it fixed
It's probably worth getting a new piece for it while it's working as it is likely to happen again eventually.
The other thing is the metal filings look like they have come from the top edge of the grooves on the right and left hand side of the pivot ball. How that bit has been broken i dont know but its likely a result of the stick coming loose and so moving further than designed.
On your first photo you can see the large slot on the right of the pivot ball. That should have clean square edges, it looks like the edge has been damaged, and thats where the bits of metal are from. Nothing major to worry about, it wont affect anything as long as the little bit's of metal are cleaned out.
    • Yeah, all the crude is used for fuels and petrochem feedstocks (pesticides, many other chemicals, etc etc). But increasingly over the last few decades, much of the petrochem synthessis has started with methane because NG has been cheaper than oil, cleaner and easier and more consistent to work with, etc etc etc. So it's really had to say what the fraction either way is. Suffice to say - the direct fuels fraction is not insigificant. Heavy transport uses excruciatingly large amounts. Diesel is wasted in jet heaters in North American garages and workshops, thrown down drill holes in quarries, pissed all over the wall to provide electricity to certain outback communities, etc etc. Obviously road transport, and our pet project, recreational consumption camouflaged as road transport, is a smaller fraction of the total liquid HC consumption again. If you're talking aboust Aussie cars' contribution to the absolute total CO2 production of the country, then of course our share of the cubic mile of coal that is used for power generation, metallurgy, etc adds up to a big chunk. Then there is the consumption of timber. Did you know that the production of silicon metal, for example, is done in Australia by using hardwood? And f**king lots and lots and lots of hardwood at that. Until recently, it was f**king jarrah! There are many such sneaky contributors to CO2 production in industry and farming. NG is used in massive quantities in Australia, for power gen, for running huge water pumps (like, 1-2MW sized caterpillar V16 engines running flat out pumping water) for places like mine sites and minerals/metals refineries. And there are just a huge number of those sort of things going on quietly in the background. So NG use is a big fraction of total CO2 production here. I mean, shit, I personally design burners that are used in furnaces here in Oz that use multiple MW of gas all day every day. The largest such that I've done (not here in Oz) was rated to 150MW. One. Single. Gas burner. In a cement clinker kiln. There are thousands of such things out there in the world. There are double digits of them just here in Oz. (OK< just barely double digits now that a lot of them have shut - and they are all <100MW). But it's all the same to me. People in the car world (like this forum's users) would like to think that you only have to create an industrial capability to replace the fuel that they will be using in 10 years time, and imagine that everyone else will be driving EVs. And while the latter part of that is largely true, the liquid HC fuel industry as a whole is so much more massive than the bit used for cars, that there will be no commercial pressure to produce "renewable" "synthetic" fuels just for cars, when 100x that much would still be being burnt straight from the well. You have to replace it all, or you're not doing what is required. And then you get back to my massive numbers. People don't handle massive numbers at all well. Once you get past about 7 or 8 zeros, it becomes meaningless for most people.
    • @GTSBoy out of the cubic mile of crude oil we burn each year, I wonder how much of that is actually used for providing petrol and diesel.   From memory the figure for cars in Australia, is that they only add up to about 2 to 3% of our CO2 production. Which means something else here is burning a shit tonne of stuff to make CO2, and we're not really straight up burning oil everywhere, so our CO2 production is coming from elsewhere too.   Also we should totally just run thermal energy from deep in the ground. That way we can start to cool the inside of the planet and reverse global warming (PS, this last paragraph is a total piss take)
    • As somebody who works in the energy sector and lives in a subzero climate, i'm convinced EV's will never be the bulk of our transport.  EV battery and vehicle companies over here have been going bankrupt on a weekly basis the last year.
    • With all the rust on those R32s, how can it even support all the extra weight requirements. Probably end up handling as well as a 1990s Ford Falcon Taxi.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
