Guys,
I had to jump start my car a couple months ago, and ever since my Airbag light has been flashing! I have tried to reset the ECU by disconnecting the battery and leaving it for a couple days.. and this hasn't worked. I've tried this twice and nothing. Any suggestions?
Any help or ideas would be great! Thanks!
https://www.sau.com.au/forums/topic/101941-airbag-light-constantly-flashing/
Had the same problem a few years ago,,,Nissan Consult fix is the only way. The Airbag system needs re-setting.
Neil.
Thanks heaps for the response... Although not too sure what you mean by
Nissan Consult Fix?? Do you mean I'll have to take it up to Nissan and have them re-set the Airbag System?
Cheers mate!
Yes, you will need a Nissan or other dealer with a Nissan Consult compatible scan tool to clear the fault codes for the airbag system.
That will only work if you haven't fried your srs/airbag control module.
It should take 5mins to plug the tool in and clear it, so it won't cost much.
Try this
Get in the car and close the door, turn the key to ignition, open the door and press the door ajar sensor button 7 times.....I think all within 10 secs.
the light should go away......if it comes back on then you have some other problems.
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
