No shit its not a case of bolting it on and driving away. You really do write some stupid shit man. I read your posts all the time and am constantly shaking my head.
I know many people with GCG turbos as well, and none of them have had problems either, however, i did have a problem
Your the one posting pretty stupid shit... either that or your making yourself look stupid. Take you pick, near enough to the same
Im not being sarcastic at all, i wasnt ever referring to your post. Just because i post after ... wow.. lemme get excited
you couldnt get it to work... thats your own problem in conjunction with your tuner. SK has posted how he gets it too work, like others before him (who dont post on here)
Just because you went through 3 turbos doesnt mean it was GCG'd fault at all.
You can get the wheel specs, you can draw your own conclusions.
You using stock BOV's Paul? :D
GCG S2 high flow (discontinued) and standard computer don't work together, upgrade the ECU.
Some tuning tips;
1. During the boost build rpm, tune it with as much ignition advance as it will take, use extra fuel (richness) to control the detonation.  This ensures that whatever airflow the turbo is producing is ingested by the engine (throttle body size is irrelevant at partial throttle openings).
2. Retard the exhaust camshaft timing, usually around 4 degrees
3. Some mild tuning of the VVT change over point sometimes helps
4. In the surge rpm zone, check the pressure drop from the turbo to the plenum.  It should be almost zero, more than 1 psi is not acceptable.  Look closely at the pipework and the intercooler.
5. In the surge rpm zone, compare the inlet plenum pressure and the exhaust pressure (the lambda sensor point is a good reference).  There should be almost zero difference, more than 1 psi is not acceptable.  Look closely at the dump, cat and exhaust.
The above (with carefull tuning) will eliminate almost all of the compressor surge, maybe even all of it.  Whatever remains you will have to manage via judicious use of the throttle.
Hope that helps
:D cheers :O
PS, this is a unique problem to the GCG S2 (500 bhp) high flow, the S1 (450 bhp) has not had one sinlge problem on the 6 or so cars we have fitted them to.
So if i got manual conversion + powerfc and hand the tuner these tuning tips they should be able to solve the compressor surge
omg, you're running a stock ECU? what a freaken waste... Go and buy an Apexi PowerFC and hand controller for $950, get it tuned and you will be fine.
So many people make the mistake... Get the ECU, fuel pump., exhaust..fmic BEFORE you upgrade the turbo!
The turbo should be the last thing that you increase in size.
perhaps u didnt read my first post......R33 gtst s1 auto(so i cant use a powerfc) running 11 psi
fmic, safc, gcg s2 highflow, full zorst, stock bov i also have a walbro fuel pump and nismo reg.
SydKid cheers for tips... much appreciated.. I just need more time and money to work on diagnosis! LOL. It has got to be something dodge with my turbs/wastegate i recokon as it seems to fix itself at higher revs and under full throttle. (well at least i dont notice it).
I have a seconds dog box on zorst (is rather a queiet zorsts) and no cat.. however is 3 inch the whole way... Could this second dog box be restricting the exhaust flow somehow?
Could my airflow sensor maxing out cause this problem?
First thing in morn once car is warmed up i dont notice it -- could this be some sort of heat related problem ie cooling oil and water lines not working correctly?
????? THere is so much that it could be!!!!!!!!!!
Cheers chris..
I was loosing power due to the disturbed airflow that was being caused by the hole in the mesh that also why i got the compressor surge. I cant say it will work for you just talk to your local tuner and see what they say.
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
