Item:HKS Hiper-D Suspension
Item Condition:Good
Reason for Selling:Swapped out of import for standard suspension
Price and Payment Conditions:1320 including Delivery
Extra Infone of the tiny little adjustors on one of the rears is broken off, looks like a really easy job to pop something on to replace the small cap, i know its a samll thing but thats all that seems to be wrong with them.. They came off a R34 GT, they will also fit a R33 GTR
Contact Details:[email protected]
Edited by buttocks
