  • Replies 51
How long does it take to recieve the appropriat cams licence.  Also where is a good place to put the fire extinisher?
You can get it on the day if need be but i would get it before hand.
Allow about 2 weeks but u will have your temporary one anyone if it doen'st trun up :P
yep, can get it on the day, nice to have it all sorted b4 hand though.
thinking of asking my old man if i can run the clubman :P will be on for donkey kong greg :P
EDIT: Savman, fire extinguisher has to be mounted SECURELY within reach from the drivers seat, ie. under your seat or something. has to be at least 900g dry chemical type (a red one) on a metal bracket.
Edited by bj_dove
Is that it for safety requirments? So rock up on the day, pay for your licence and screw a fire extinguisher to the floor? Cool.
XRATED - You'll need a battery locating sticker too. Just a blue triangle cut out of book covering 'contact' would do.
BOV - Thats soft! Your GTR would be awesome on that course.
Getting into the 49s is the plan this year.
BJ,
I picked up a Quaife the other day. So will try to have that installed. Also did a set of stainless tuned pipes and 2.75 in system. I think its pumping a little harder now - but still gotta get it around that bloody bend eh? :)
PS: Stu I know Im soft but Im gunna have to wait until I scratch it first and it dont matter after that. Once the Mrs runs the mags into the curb I'll be right :D
Cheers
Have been helping a mate import an nice black R32 GTSt. We just picked it up from the docks & seeing it's as good as we though it would be hes giving it a tidy up this weekend and should be running the Hillclimb.
thought my ears where burning!! hi stu and everyone else. yes, fixing up the bodywork, not much to it since dad's good at that sort of thing (im hopeless)
took the car out to baskerville yesterday to see what ive got to play with. i dont think i was driving it correctly, i also wasnt thrashing it either. just wanted to give it abit but was breaking fairly early for the corners. had to remember which way the track went (haha). its been over ten years since i had a blast. was doing 1.15's i think. i didnt have stop watch, only the dash clock and then counting after it clicked over a minute. heal/toeing was a bitch too.
front brakes started to warp so i gave it away for the day.
ive found this site which some tunning tips that might be of use for people.
http://www.rb20det.com/tuningguide.html
hope to be at the hillclimb but ive just lost my job so it will make thing diff for a little while till i find another (let me know people if you know of any jobs going)
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
    • Ok now I’m extremely jealous
