I know what 4WS is. I searched for it on here and didn't find anything.
Can someone explain to me how it works (as in when it works). To my unederstanding 4WS only kicks in under 40kmh (that's how it was on my friend's eunos I think).
I also have a friend with an MX6 ??? and he said he tried drifting and the 4WS just f**ks it up for him.
R32 GT-R do have 4WS right? When is it active?
Thanks in advance
https://www.sau.com.au/forums/topic/101987-4ws/
Thanks in advance
The 4ws system in Skylines is called 'HICAS' - do a search for that and you'll turn up a bazillion threads with the info you need....
Edited by Ant
https://www.sau.com.au/forums/topic/101987-4ws/#findComment-1872955
HICAS, rear wheels turn 3mm either way after 80klm. Theres an extra 2 oil lines that run to your rear wheels that are fed pressure once you hit 80klms. If have trouble drifting with hicas ( need slightly quicker reaction time ) can buy a kit to block of the 2 extra lines or can simply put to screws into the lines to stop the pressure being fed to your rear wheels.
https://www.sau.com.au/forums/topic/101987-4ws/#findComment-1874877
thanks for that falcon
helps explain it quite easily.
so the advantage of HICAS is that you can corner better at higher speed right?
Wouldn't it wear the tyres faster and also make it harder to break traction?
Is the rear wheel steering as responsive as the fronts? Like is it quick enuff that it can be safe to go from OP lock to OP lock?
https://www.sau.com.au/forums/topic/101987-4ws/#findComment-1876442
Yup, the whole point of HICAS is to stop the rear end from breaking traction and allow ordinary mortals to corner faster. Hence why drifters and those that like to hang the tail out hate the system.
Tyre wear - shouldn't make any difference, if anything it would reduce wear. The angles shown on that diagram are exaggerated, in reality the system only changes the rear wheel angle by < 1.5 degree.
Quite safe to go from OP lock to lock - the reaction time of the system is very fast.
https://www.sau.com.au/forums/topic/101987-4ws/#findComment-1876897
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
    • Are you talking about the oil squirters? There is only one place for them to go. Yes, you have to drill the holes. Yes you have to obtain the correct oil squirters (I presume there is some sort of aftermarket option available, because original turbo ones are going to be a diminishing resource).
