mr 32 4door Posted January 16, 2006 Share Posted January 16, 2006 hay all, has any one bolted a turbo set up on a non turbo motor? did u lower the compretion? or just bolt it all on? i have been told that wif stock boost the setup will last a while, any help would be great. oh one more thing, im only doin this becouse i have all the turbo setup at home and it would be alot cheaper to do it this way. cheers every one Link to comment https://www.sau.com.au/forums/topic/102009-turbo-on-a-non-turbo-rb20/ Share on other sites More sharing options...
Medium Dave Posted January 16, 2006 Share Posted January 16, 2006 Justa a quick aside to this question, would the RB20 turbo set up be ok on a RB25 NA - would this last? would you get away with the RB25DEt computer? I ask merely for information Link to comment https://www.sau.com.au/forums/topic/102009-turbo-on-a-non-turbo-rb20/#findComment-1870058 Share on other sites More sharing options...
grim32 Posted January 16, 2006 Share Posted January 16, 2006 I cant see a problem with it. My mate bolted a t4 setup on his ef falcon (210000kms) and on 10psi its still going strong with 315hp at the wheels. Link to comment https://www.sau.com.au/forums/topic/102009-turbo-on-a-non-turbo-rb20/#findComment-1871180 Share on other sites More sharing options...
Turbine Posted January 16, 2006 Share Posted January 16, 2006 RB20DE turbocharged is what i have in my drag car at the moment. On a street car it should be great, higher compression, more low down response. With moderate boost and a good cooler, should be fine. Link to comment https://www.sau.com.au/forums/topic/102009-turbo-on-a-non-turbo-rb20/#findComment-1872334 Share on other sites More sharing options...
mr 32 4door Posted January 17, 2006 Author Share Posted January 17, 2006 thanx for ya help guys, just tryin to work out if i am beta of just buyin a turbo motor from the start Link to comment https://www.sau.com.au/forums/topic/102009-turbo-on-a-non-turbo-rb20/#findComment-1874181 Share on other sites More sharing options...
Nismo_Boy Posted January 17, 2006 Share Posted January 17, 2006 thanx for ya help guys, just tryin to work out if i am beta of just buyin a turbo motor from the start <{POST_SNAPBACK}> Yes. But if you and your mates are doing the conversion, you might as well have a crack at it, my buddy made 150rwhp on an auto ca18de S13 that he bolted up a turbo to. Link to comment https://www.sau.com.au/forums/topic/102009-turbo-on-a-non-turbo-rb20/#findComment-1874343 Share on other sites More sharing options...
Squizz Posted January 17, 2006 Share Posted January 17, 2006 I did that conversion to my old 32 GTS back in '02 and she went like a rocket. Should be some threads in the archives on SDU. Link to comment https://www.sau.com.au/forums/topic/102009-turbo-on-a-non-turbo-rb20/#findComment-1875903 Share on other sites More sharing options...
