Hmmm it seems that I have aquired a very disturbing noise on the left side of my engine. Its especialy noticable on a cold start or when the car has been turned off for a while. Well how do i describe it ........ well its like a knock noise that is quite loudish and starts off about 6 seconds apart and then gradualy increases to 8 seconds and so on ... I notice the noise is louder when i rev the car hard and then back off ... its almost like there is a knock as soon as the turbo winds down, so im a little suss about the turbo ....
I aquired the noise eva since my car detonated at about 240, im not 100% sure but at the time i think the boost spiked and the pressure in the lines ended blowing the hose from plenum to the fuel regulator off causing the car to run lean while doing 240, and melted 2 brand new platnum plugs and left me with this disturbing noise ...
So after giving yo all a run down of my problem, does anyone have any ideas as to what may be causing the knock noise ??
https://www.sau.com.au/forums/topic/10201-disturbing-noise-from-engine/
does it go away after a while?
ive got the same thing on a cold start. mines a blown exhaust manifold gasket which i should fix soon...
if its that then nothing to worry too much about. gasket costs $80-$90 and a good afternoon pulling everything off
other things it could be are lifters which can be helped by using certin types of oil but inevitably will require the head to be rebuilt.
or it could be a valve as mentioned. go to a mechanic and let someone listen to it in person. its hard to diagnose these thigns over the interent
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
