  • Replies 134
Posted Images
Spoke to Bosch Australia today.
'Apparently' they have ZERO stock, Bosch Germany where the Z32's are manufactured have had a problem of some kind halting production.
I can get a very limited number of AFM's BUT no where near the 31 that we need at the moment. I have been told to call back every 2 days as it shouldn't be too long at all.
I'll make a few more calls tomorrow and see if I can scab some from various places around aus to make up the numbers.
Obviously I won't send out deposit details yet..
Sorry ppls, if your keen you may have to wait a little longer. :S
Its been a slow day today, many many phone calls. :S
I was unable to find a wharehouse that had any z32 airflow meters.
I'm expecting a call from Bosch tomorrow, I will know where I stand with regards to a time frame then.
Please bear with me as the group buy will definitely be going through.
WHEN is in the hands of Bosch Germany.
Aparently they are a bit scarce at the moment... I bought one less than a month ago from Petroject in Vic.. they said a number came in to the country from Germany, and they were only allocated 2 units of 10 that they requested. I got the last one they had in stock :P
They are indeed scarce.. :(
Bosch Australia have 20 items coming in. They won't be able to supply us with the required number of airflow meters until May. :D
Sorry for the hassle peoples. Early January the airflow meters were available, a production issue occured resulting in no AFM's. :P
I will PM every one as we approach the time and see if your still interested in an AFM and create a new group buy.
For those in desperate need for a Z32 (VG30DETT) airflow meter APC appears to have them listed at $360 which is a pretty good price.
http://www.apc-racing.com/browse.asp?cat=14&car=11
is this group buy still going on?
z32 fits r32 gtst right?
They will fit the 32 gts-t with the tomei plug or a plug from a vl but it will not work without a piggy back ecu or aftermarket of some sort.
Greg
Guest
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
