DFECTV 33 Posted January 16, 2006 Share Posted January 16, 2006 Hi peoplez, i just installed a used GFB bleed valve in my R33 GTST and i was wanting to turn the boost up. Being used i dont have any instructions or box (got it 4 free of a mate) and now i cant turn up the boost.... When new do they come with a little tool or are you ment to just use a allan key. THANX Link to comment https://www.sau.com.au/forums/topic/102022-turn-up-boost/ Share on other sites More sharing options...
7yphon Posted January 16, 2006 Share Posted January 16, 2006 Allans Key but doesnt the R33 have a boost cut? Link to comment https://www.sau.com.au/forums/topic/102022-turn-up-boost/#findComment-1870258 Share on other sites More sharing options...
DFECTV 33 Posted January 16, 2006 Author Share Posted January 16, 2006 Not to sure anyone know what i can boost it to before boost cut kicks in Link to comment https://www.sau.com.au/forums/topic/102022-turn-up-boost/#findComment-1870308 Share on other sites More sharing options...
nathn_r33 Posted January 16, 2006 Share Posted January 16, 2006 i have mine set at 10 Link to comment https://www.sau.com.au/forums/topic/102022-turn-up-boost/#findComment-1870325 Share on other sites More sharing options...
RANDY Posted January 16, 2006 Share Posted January 16, 2006 Mine's a boost tap, not a bleed valve. I've got mine set at 8psi. Link to comment https://www.sau.com.au/forums/topic/102022-turn-up-boost/#findComment-1870397 Share on other sites More sharing options...
RANDY Posted January 16, 2006 Share Posted January 16, 2006 If it has an allen-bolt on it, it's prolly the tap-kind that we're all buying here. If so, turning the bolt so that it goes inwards will increase the boost, but do it ever so slightly at a time, otherwise you'll overboost very quickly. If nothing happens when adjusting, then you have it installed incorrectly. Link to comment https://www.sau.com.au/forums/topic/102022-turn-up-boost/#findComment-1870410 Share on other sites More sharing options...
