Contact Details:pm me
Have sum parts for sale still, some new listings all have to go, cluttering the garage up.
+One R34 GTR Stock injector - $60
+Used Nismo Oil cap - $35
+Used R32 GTR radiator Hoses top n bottom - $40
+New Large Size battery cover box with straps - $15
+3 inch muffler only used for less than 1K - $70
+Modified stock exhaust originally R33 GTR modified to fit r32 GTR - front pipe back - $100
+GT side skirts for BNR32 GTR high filled ready to be painted and fit. - $300
+3 x OEM plenum gaskets for r32 GTR - $15
ADDED parts
+ R32 GTR PUMP - $140
+ R32 ROLL CAGE - $750 (with driver sunvisor adaptor)
+ Used GREDDY TRUST INTERCOOLER 70mm think - $600
+ Used 3inch CAT converter with flanges - $80
All Prices are neg within reason.
EDIT - 20th of July 2006 NEW pics added
Edited by godzl1975
https://www.sau.com.au/forums/topic/102029-fs-r32-gtr-parts-sydney/
  • Replies 52
(Use this as a guide for new threads. Delete and/or copy the fields as needed - dont forget to add your location in the description field above. Delete this message)
Item:R32 GTR Brakes
Item Condition:good
Reason for Selling:Upgraded to brembo
Price and Payment Conditions:$799
Extra Info:Comes with all four rotors and brake pads
Contact Details:0403326319
Will be adding pics up soon. pm me if you have any questions. thanks
Pics added!!!
Up for sale now too. is my 17 by 9 inch Squarossa mags with brand new Nexan 255x40x17 tyres (less than 150km use)
Asking price is $1300 neg tyre replacement value is just over $800
Perfect Fit for R32 GTR fills the gaurds up nicely, they have been resprayed with silver/chrome paint. NO centre caps. The pic was taken before it was painted, it is more silver now.
Edited by godzl1975
I'm after r32 gtr brakes, just the fronts though....
If willing to seperate pm me your best price.
SSS automotive quoted me 400-450... for fronts with good callipers and plenty of meat on the rotors..
hey dude,
iam neg with prices...ill take 620 for the lot if your interested? let me know thanks aaron
  • 3 weeks later...
These Items still for sale!
+ Sun visors for R32 Gtr will fit GT St's as well - $25 each
+ Blitz Twin BOV for GTR's will fit into stock location...R32, 33, 34 - $350 make people take notice!
+ R32 GTST rear quarter interior trim - $45 each
+ New Narva 115mm Angel eye driving light kit - $90 (never used just packaged opened) 12V (headlight conversion, make your car look like a beemer headlights)
+New Narva tone 100mm 12V disc horn part no 72515 - $15
+New Carfit HID feeling high powered Halogen H4 12v100/90W - $30
+One R34 GTR injector - $50 in good working order
+R32 GTR full Roll cage fully padded $800 (all bolts included etc)
+Brand New Nangkang 18 inch Tyres 265'sx2 and 235'sx2 can separate - $400 for 265's and $300 for 235's
  • 3 weeks later...
+Blitz Twin BOV for GTR's will fit into stock location...R32, 33, 34 - $400 (willing to separate for people who want only one)
+New Narva 115mm Angel eye driving light kit - $90 (never used just packaged opened) 12V
+New Halogen H4 12v100/90W - $30
+Brand New 18 inch Nangkang tyres 2x265 and 2x235 wide - $700 for the set
+R32 GTR 7 Point Roll Cage with padding - $800
+Used Nismo Oil cap - $45
+Used Stock R32 GTR clutch - $150
+Climate control unit for R32 - $80
+Used R32 GTR radiator Hoses top n bottom no cracks or bubbles - $50
+R32 GTR driver side seat, has small holes on driver side bolster - $300
+New Large Size battery cover box with straps - $20
Pm me offers. thanks
NEW EDIT!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
